Looking for mpg
Old Feb 11, 2013 | 10:27 AM
btm991's Avatar
btm991
Looking for mpg
So I just got my truck back from the shop after getting an icon 4.5 lift with 20" bmf novakanes and 37x13.50 toyo m/t's and I took it straight on a 250 mile round trip drive and I knew I was going to have a loss of mpg but I only got 250 miles out of a fuel tank of fuel lol. Now I'm wondering if I added a cold air intake if that would maybe help get some mpg back?
Old Feb 11, 2013 | 10:30 AM
cirrus365's Avatar
cirrus365
Thats what is called the hidden cost of a lift and big tires. Only real option for better economy, other than the obvious, is tune and delete. Dont waste your money on an intake.
Old Feb 11, 2013 | 02:08 PM
stangr8cr's Avatar
stangr8cr
The mileage sucks for sure. I went from a 37-13.50-20 Pro Comp Extreme Terrain to a 35-12.50-20 Nitto Trail Grappler M/T to see if it helps. Best mileage I got from the Pro Comps on the highway was 13.47mpg with a 3.31 rear end. I'm not expecting much back but I could live with 15mpg. After all, we don't buy these things because they're economical I have a 3.5 inch lift if it matters. Now I just have to get some miles on these new tires!! I'll post back after some driving to compare.
Old Feb 11, 2013 | 03:03 PM
CountryD's Avatar
CountryD
How about some pics? Would love to see your truck
Old Feb 11, 2013 | 03:23 PM
Hdslider's Avatar
Hdslider
Just a ? how are you getting ur speedo calibrated with a 3'31 rear gear and 20 s? with those tall of tires.
Old Feb 11, 2013 | 03:38 PM
stangr8cr's Avatar
stangr8cr
Unfortunately right now, I'm using my GPS as a speedometer just to keep the po po from requesting donations from me As soon as the engine warranty is up, I'll be tuning it with the H&S Street Tuner. (We have emissions testing) In the meantime, I may have the dealer set it up for the largest wheel/tire combo for the 3.31 rear.
Old Feb 11, 2013 | 03:50 PM
Hdslider's Avatar
Hdslider
Then you really. Have no idea on what mpg your getting since your odometer is way off.
Old Feb 11, 2013 | 04:22 PM
stangr8cr's Avatar
stangr8cr
I see what you're saying. I'll have to sit down and calculate it with corrected math. I really don't drive the truck as often as I'd like. She is my workhorse for my boat and car trailer so the mileage doesn't mean that much to me.
Old Feb 11, 2013 | 04:46 PM
jowens1126's Avatar
jowens1126
Welcome to the Lifted Truck World. This is why so many do a PSD Conversion. 8 MPG on a 351W or 18 MPG on a 7.3 PSD.
Old Feb 11, 2013 | 05:18 PM
ruschejj's Avatar
ruschejj
Ha, I calculated my odometer and mph to be just under 5% off just going from stock 65 to 55 on the tires.
Basically, my speedo reads 5 mph fast when I'm going 70mph. (Speedo reads 75 and GPS reads 70)
Old Feb 11, 2013 | 06:03 PM
btm991's Avatar
btm991
I just took mine for a drive and with GPS it was basically right on. It was at most 1 mph faster on GPS than my speedometer
Old Feb 11, 2013 | 06:38 PM
Hdslider's Avatar
Hdslider
What. Rear gear do you have. And what size wheels were stock for truck?
Old Feb 11, 2013 | 06:58 PM
kper05's Avatar
kper05
Put it in engineering mode and you'll get yet another speed.
Old Feb 11, 2013 | 07:13 PM
Tom's Avatar
Tom
Unfortunately the only thing that will really give you any kind of improvement is slowing down at this point. Lifting the truck makes it push more air and increases wind resistance, and bigger tires increase rolling resistance which makes the situation worse.
Old Feb 11, 2013 | 07:22 PM
kper05's Avatar
kper05
I lost around 2 MPG simply switching from the OEM 275/65/R18 ContiTrac's to Nitto 295/70/R18's with stock suspension.
Add large tires and change the suspension and you'll drop quite a bit based on what I experience with such a simple tire change.
My last tank was 14.0 computer average without a trailer.
For example, if I were to spend an entire tank driving locally I used to be in the low 16's with the OEM tires.
Now I'm in the low to mid 14's in the winter and high 13's, low 14's during summer if I were to do the same driving.
