i have a 77 f150 4x4 my blinkers work good when the lights are off. but when i turn the headlights on the left blinker at times either blinks really slow or not at all. and it doesnt do this all the time. i was wondering if it was the switch or where to start looking. thanks
Probably not the switch since it's working. If you won't to do it right pull the instrument cluster out. Clean the paper circuit with rubbing alcohol. Clean all contacts and where the main cluster plug goes in. The replace your blinker bulbs. Plug it back in and see what you got.
The guy I bought mine from had replaced 2 of the sockets. I replaced the other 2 and still had the same problem. After checking his work, I found he had wired one of the sockets backwards.
