1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
MPG Improvements
Old 02-17-2012, 11:03 PM
airborne0130's Avatar
airborne0130
airborne0130 is offline
MPG Improvements
I have a 2008 F250 4x4 with a V10 , im running on 37inch tires with 6in lift so I know Im not going to get 15+ MPG but Im curious as to was mods people have done to a truck like this and what kinda MPG improvements they have seen...Im averaging 8-10 MPG and im not hard on it and i baby the truck. Thanks for the help
Old 02-17-2012, 11:15 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
It's easy. Put diesel in it.
Old 02-18-2012, 01:56 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Put a Y pipe on it..
Old 02-18-2012, 03:26 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Go back to stock size tires and stock height
Old 02-18-2012, 07:08 AM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
You don't need a Y pipe, the '05 and newer trucks have a much better designed exhaust system. As was said before, the lift and big tires are killing your MPG. I would say you are getting good gas mileage for what you have.
Old 02-18-2012, 07:22 AM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
yeah your mileage isnt bad with that setup. Thats about what im geting on 34.5" tires. Clean your MAF sensor if you havent.
Old 02-18-2012, 08:18 AM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
I average 10.3 now with no lift and 285's.
Old 02-18-2012, 10:38 AM
IslandBlueV10's Avatar
IslandBlueV10
IslandBlueV10 is offline
Regear your axles, but at the cost of that it will take a very long time for it to pay off.
Old 02-18-2012, 11:40 AM
biz4two's Avatar
biz4two
biz4two is offline
Thumbs up
Welcome to FTE!!!
Thinking the same...with going with gear change. Speaking of gears...airborne...what gears you running?
Another thought...is go with 5-Star Tuning. They are an FTE sponsor...and know the V10 3v personally.
Got a V10 Ford F250/350/450/550?
Good luck with it...
biz
Old 02-18-2012, 12:33 PM
onug's Avatar
onug
onug is offline
I drive a lot of freeway miles unloaded and average 10.5-11mpg. You're doing great with your lift and tires.
Old 02-18-2012, 02:06 PM
airborne0130
Ok thanks I thought people was averaging 12-15 with my setup ... Not sure what gears are in it due to me buying the truck as I described ... Does anyone have a 5 in exhaust on there v10 is so did it improve mpg any ? Also what about cold air intake will that improve my mpg
Old 02-18-2012, 02:57 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
5" exhaust is WAY too big, if anything it will hurt your performance and MPG. CAI won't do anything but lighten your wallet. Unfortunately, a lift and big tires kills your gas mileage. Nothing you can do about it. As they say.....If you wanna play, you gotta pay!
The 5 Star tuner may help a little bit, but othe than that the only thing you could really do to improve your mileage is put the truck back to stock height and put stock tires on it.
Old 02-18-2012, 03:11 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
Another thing, was the truck ever reprogrammed for the larger tires?
The 37s are roughly 12% larger than stock. If the truck wasn't reprogrammed, your speedometer is reading 12% lower than your actual speed and the odometer is racking up 12% fewer miles than you are actually traveling, which also means you are actually getting about 12% more MPG than what you are figuring.
Old 02-18-2012, 03:47 PM
airborne0130
To my knowledge the truck has never been reprogrammed , I know my speedometer is off by about 5-8 mph but I did the calculator math on the mpg and I'm getting around what the dash is telling me
Old 02-18-2012, 03:51 PM
dualwheels66
Your odometer is off also, so the computer thinks you still have stock tires. Also I would bet your trans is shifting at the wrong times.
Quick Reply: MPG Improvements
