Sponsored by: Real Truck
"Clunk" on startup?
Old Feb 17, 2012 | 10:12 PM
Mike E.'s Avatar
Mike E.
"Clunk" on startup?
Hi folks,
Just noticed a new phenomenon with my '01 F350 V10.
About 2-3 seconds after starting it up there is a dull 'thud' close to my feet.
Not sure if it's normal and I've never just noticed before, or ???
Also, to read the PCM for transmission codes do I need to head to the dealer as I've heard that only the 'good' readers will pick up tranny codes?
Thanks,
Mike
Old Feb 18, 2012 | 12:43 AM
bohiaa's Avatar
bohiaa
Not sure on the 350's but the 250's they didn't greese the drive shaft good enoulf.
while starting to move the truck you will hear a thud.
you can pull the ds, put a little greese in there and enjoy a clunk/thud free driving.
I belive thers a seal on it, with a metel keeper. many have said they have cut this only to replace it with a wire tie. with no issues
Old Feb 18, 2012 | 08:07 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You are hearing the blend door for the heater under the dash. It works off vacuum, so when you start the truck, the vacuum pump comes on. When there is enough vacuum the door closes with a clunk.
Very common.
Old Feb 18, 2012 | 11:40 AM
Sand_Man's Avatar
Sand_Man
Yup, mines loud enough to startle passengers. I like to act as if something's seriously wrong for first-time passengers, especially if it's late at nite and raining out.
Old Feb 18, 2012 | 01:04 PM
Fordfanatic4life's Avatar
Fordfanatic4life
HVAC blend door..
totaly normal operation..
the vaccum pulling that door can make a rather loud bang when your not prepared for it.
Old Feb 18, 2012 | 01:26 PM
Mike E.'s Avatar
Mike E.
Thanks for the responses guys.
Maybe I'll continue to try the 'cringing face' with my wife for a bit longer to see if she'll concede to an upgrade.....mmm, '11 F350
Cheers,
Mike
Old Feb 18, 2012 | 02:58 PM
Fordfanatic4life
if memory serves me right if you turn the HVAC to OFF before shutting down the truck, it wont make that noise when restarted..
but tbh i dont ever remember to try it when im actualy out in the truck.
but i have been could offguard but that thump on occasion and jumped.
diesel_dan
Oct 9, 2018 05:26 PM
WarX
Jan 10, 2015 01:16 PM
GUNNERDOG
Jun 4, 2010 07:18 AM
'02strokerpilot
Dec 2, 2009 03:32 PM
QFD90
Mar 14, 2005 06:02 PM
