T98A 4 Speed Speedo Cable
Old Feb 17, 2012 | 08:28 PM
Tony_C's Avatar
Tony_C
Anyone know where I can pick up a C3TZ-17260-Y for my 62 T98A 4 Speed? Is the Mac C3TZ-17260-ED the same?
Old Feb 18, 2012 | 01:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Tony_C
Anyone know where I can pick up a C3TZ-17260-Y for my 62 T98A 4 Speed? Is the Mac C3TZ-17260-ED the same.
Both these cables are incorrect.
I'm assuming your 1962 F100 is 2WD / Please, when asking questions, list all the pertinent info.
C4TZ-17260-M .. Speedometer Cable & Housing Assy / 81.17" long / Obsolete
Applications: 1961/62 F100/250 2WD & F350/700 w/Warner T-98 4 Speed Manual / 1961/64 B500 w/Warner T-98 4 Speed Manual.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
CARPENTER NOS OBSOLETE PARTS in Concord NC has ONE = 800-476-9653.
C3TZ-17260-Y .. Speedometer Cable & Housing Assy / 77.00" long / Obsolete
Applications: 1963/64 F100/250 3 Speed Medium Duty & Borg Warner T-98 4 Speed M/T's.
C3TZ-17260-FA (replaced C3TZ-17260-ED) .. Speedometer Cable & Housing Assy / 69.82" long / Obsolete
Applications: 1961/62 F100/250 3 Speed Light Duty M/T / 1961/64 F500/700 w/Clark 5 Speed Medium Duty M/T.
Old Feb 18, 2012 | 03:43 PM
camperspecial65's Avatar
camperspecial65
Am I correct in assuming this is the cable ONLY...not the case and cable ??
- cs65
Old Feb 18, 2012 | 04:14 PM
Tony_C's Avatar
Tony_C
Thanks for the info Bill. Yeah, 2wd to 4wd would make a difference. I remedied any omission from now on with a signature.
No, I need the whole cable with the case. It melted against the header.
Old Feb 18, 2012 | 04:22 PM
NumberDummy
You assume incorrectly, notice the basic part numbers.
But it's my fault you assumed incorrectly, because I shoulda said Speedometer Cable & Housing Assy (which it does say now in post 2...and below).
C4TZ-17260-M .. Speedometer Cable & Housing Assy.
B9AZ-17262-A .. Universal Woven Steel Core Kit. Cut it to fit, coat it with graphite, install in the housing.
This same puppy dog is available at every autoparts store, excepting it won't have a Ford part number.
Since Tony was referring to 17260, I assumed he didn't want just the woven steel core.
Every cable and housing is 17260...except with speed control. Then (in most cases), there's a upper and lower 9A820 = cable and housing.
greenbeaut
Jun 16, 2017 10:13 AM
1950FordF1
Oct 25, 2016 08:49 PM
tbm3fan
Sep 2, 2010 12:55 PM
judi48
Jul 11, 2008 01:59 PM
RDON
Mar 3, 2005 09:02 AM
