1966 Auto Steering Column issue
Old Feb 18, 2012 | 08:45 AM
1966MN's Avatar
1966MN
Swapping out Steering column on truck. 1966 f100 camper spec. with auto. One I have auto handle missing and linkage broke. Got a 66 from bone yard that was rebuilt by guy.
Question: the one I have in my truck is shorter then the one that come from bone yard. He told me that in 67- 72 they were a little shorter. Is that right?
I'm trying to move the floor shift back to column and am coming up Zero on column-tranny linkage, I have the CruiseOmatic tranny. Know of anyone that might have that linkage?
Thanks Guys,
Will post pics of restore soon.
Old Feb 18, 2012 | 03:48 PM
camperspecial65's Avatar
camperspecial65
The power steering columns are shorter versus the manual steering columns ...Im all but sure that holds true for the 67-71 setup as well...A tape measure is invaluable in this kind of swap when you are dealing with two different generations of trucks.
- cs65
Old Feb 18, 2012 | 05:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1966 F100 steering column with P/S is a different length than without.
The differences have to do with the shift tube, steering shaft and mast jacket (outer steering column shroud). Everything else is the same.
Old Feb 18, 2012 | 05:56 PM
1966MN's Avatar
1966MN
Both are from manual steering. I guess what Im asking is the later years, 67-72 shorter? Coulumn should work if I can get the linkage pices thru firewall. its a litle bigger then mine ancan't seem to make it thru the whole..
thxs
str8patina
Feb 15, 2016 04:43 PM
sullyda1
Jan 11, 2013 06:03 PM
oldblu
16
Jun 8, 2011 05:10 AM
willys_gasser
Jul 29, 2008 06:34 AM
Bob Crain
May 12, 2004 08:36 PM
