Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
removing headlight assembly drivers side 08
Old Feb 17, 2012 | 05:05 PM
rickfar's Avatar
rickfar
Does anyone know how to remove headlight from a 2008 escape? I can see top 2 bolts but I know there has to be more. Pleas dont tell me you have to take bumper cover....... there has to be a way as i cant see how you even change the small side marker bulb it seems impossable..........help
Old Feb 17, 2012 | 06:49 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If you dont have your owners manual, go here to dl it:
https://www.fleet.ford.com/maintenan...ls/default.asp
Looking at Alldata, It doesnt show pulling the headlamp to change it. It twists out from the backside.
Here:
File Type: pdf
Old Feb 17, 2012 | 07:27 PM
rickfar's Avatar
rickfar
Here:
I want to replace headlight assembly as it has tons of moisture in it and i cant get it out but you did give me insight on how to change the side marker light thanks.....
Old Feb 17, 2012 | 09:22 PM
Archion's Avatar
Archion
According to Alldata and Mitchell, removing the headlamp assy requires R&I of the bumper cover, the two lower bolts are behind it... sooo how bad is that condensation?
Dakrri
Mar 27, 2010 04:46 PM
gmeff
1997 - 2003 F150
Mar 10, 2010 06:53 PM
bowhunt24
2004 - 2008 F150
Aug 5, 2007 10:36 AM
ABFord
Jul 2, 2007 12:09 PM
TNMCDANIEL2
Mar 8, 2005 02:03 PM
