Need some help guys?
Old Feb 17, 2012 | 05:02 PM
EF250SD's Avatar
EF250SD
Hello guys im a new member on here. And I had a question and thought yall could help me out. I have a friend of mine that has a 2005 F250 Harley Davidson for sale and was wondering if it was a good truck. I've heard a few things about the 6.0 it has. But don't really now as much. The truck has 120,xxx. I don't know if this is the right place for the post so sorry but any info could help thanks Eric.
Old Feb 17, 2012 | 08:46 PM
zhilton's Avatar
zhilton
First off, welcome to FTE. You really want to be in the 6.0L...which is a couple of forums down from this one (I'll see if a moderator can move it). This is what I'd look for when it comes to a used 6.0L:
*White residue around degas bottle cap
*Color & condition of the coolant
*CAC boot condition
*EOT/ECT delta (would need something like a ScanGauge II to see this)
*FICM voltage (also need a ScanGauge)
*EGR cooler condition
*Oasis/CarFax report
*Cold starting issues?
*Hot starting issues?
*OEM bolts or studs (look for the bottom row of bolts/studs outside the rocker boxes)
*Aftermarket parts (intakes, exhaust, tuners...you really don't want 'em)
Don't let anyone convince you the 6.0L is a bucket of bolts. True, in the early years they had issues. But most of that was lack of training and a couple of minor design issues. The 6.0L is full of all kinds of information on them and allot of knowledgeable folks.
Old Feb 17, 2012 | 08:53 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Moved to 6.0 forum
Welcome to FTE Eric!
powerstroke72's Avatar
powerstroke72
Originally Posted by SteveBricks
Moved to 6.0 forum
Read my mind.....thanks Steve.
Old Feb 17, 2012 | 10:53 PM
EF250SD's Avatar
EF250SD
Thanks guys and thanks for moving it. Zhilton what color should the coolant be and what is everything else suppose to be at in order to be good. Is it cool if I pm you for any more questions?
Old Feb 17, 2012 | 11:18 PM
BLADE35's Avatar
BLADE35
Has your Buddy done any work to the HPOS 05+ had a couple issues There GREAT Trucks if kept in Spec
Your really going to need a gauge to see How well it runs or that should give a good Idea anyway
Autozone sells a ScanGauge II its great for this truck
ACRONYMS FORD
https://www.ford-trucks.com/forums/821641-acronyms.html
You might need to refer to this list^^^^^^^^^ ,for stuff like HPOS=High Pressure Oil System
Most on here Write in a form of shortcuts
Oh heres 1 MOre thread to read
Buying used 6.0
https://www.ford-trucks.com/forums/9...used-6-0l.html
And welcome to FTE
Old Feb 17, 2012 | 11:20 PM
zhilton's Avatar
zhilton
Until you get 25 posts, you won't be able to PM me. If it's running OEM coolant...it will be gold/dark yellow in color. If the previous owner has flushed and gone with an extended life coolant it could be several different colors...I hear the Cat ELC red.
If there is white residue around the degas bottle (overflow tank) that says either (A) the cap needs to be replaced since it's not holding up to the 16psi spec or (B) you've got an EGR cooler/headgasket leaking. Not the end of the world, but it's something I want to know about ahead of time.
Unless your planning to build a stump pulling monster (more than 500hp) the OEM air filter & intake is the best you'll find for these engines. I'm not a fan of chrome under the hood. An aftermarket intake isn't a bad thing...but if it's got one...what else has been done to the truck? Not all tuners are bad...but there are a couple out there that are just down right murder on the truck's components.
The Oasis is a Ford only report that will tell you all repairs (warranty & non-warranty) done to the truck at any Ford dealership. The CarFax might show other repairs done at a non-Ford shop.
The Hot/Cold starting issues can be a couple of things but you shouldn't have any trouble starting the truck when it's 20F outside and it's been sitting all night unplugged. Same goes for when it's hot. Should be able to fire it right up after it's been shut down following a 20 mile run on the interstate. If not, would want to know why.
The EOT/ECT delta is the difference in Engine Oil Temp & Engine Coolant Temp. If it's more than 15F while driving down the interstate...more than likely a clogged oil cooler. Again, not the end of the world...but a serous & time consuming repair.
The CAC (Charge Air Cooler) boots are those 4" OD rubber hoses that carry compressed air from the turbo, to the intercooler and back to the intake elbow. Over time the one by the turbo can crack & start leaking CCV oil vapor. Not a hard DIY repair...but it's worth looking for.
The one that I keep leaving off that list...aftermarket oil filter. The oil filter cap should look like the one on the left side of this photo:
If not, buyer beware. Someone had been running aftermarket oil filters on the truck. They may fit, but they're not the best for the engine and can/will cause starting & filtering issues. If you have more questions...feel free to ask 'em here in this thread.
jonjon219
Mar 24, 2016 08:12 PM
wheelman21
Mar 14, 2016 05:28 PM
Peterbilt376x
Dec 11, 2013 06:17 PM
Walt the Welder
Oct 24, 2011 04:18 PM
spanky32354
Feb 8, 2009 11:45 PM
