79 f250 kickdown question
Old Feb 17, 2012 | 04:33 PM
captain1997's Avatar
captain1997
Hey guys hope someone has a suggestion for this problem. I have a 79 f250 4wd drivetrain and chassis 400 and c6 automatic. the body was gone so I got a 81 f150 rust free body and set on it. It looks sweet. The question I have is the 400 was recently rebuilt and has a new edelbrock intake and carb but the kick down rod is not even close to fitting. Is there a such of a thing is a generic kick down cable I can get for it and if so how the heck do you adjust it. Im scratching my head on this one. Been to the salvage yard and got a couple of different rods and none close. The trans was just rebuilt when the motor was done and I dont want to continue to drive it without the kickdown rod. Any help or advise would be great. Thank you.
Old Feb 17, 2012 | 05:36 PM
jim collins's Avatar
jim collins
It wont hurt the trany with it not hooked up. I drove my 79 bronco 15 years with out one,you just won't have a kick down,which you may want. You will most likely have to extend the rod to fit your carb. I had the same carb on a 460 in my bronco,never needed the passing gear with the extra H.P. the 460 put out,so just left it off.
Old Feb 17, 2012 | 05:37 PM
smithet's Avatar
smithet
Lokar makes one, I got one through summit. Little pricey though....
Lokar KD-20C6HT - Lokar Hi-Tech Kickdown Kits - Overview - SummitRacing.com
Old Feb 17, 2012 | 05:45 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Don't know about Edelbrock, but Holley makes an extension bracket that extends the kickdown rod to the new arm location.
Old Feb 17, 2012 | 06:15 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I used some scrap flat stock, drilled a couple holes and bolted it fast. Took some adjusting to get it just right but it was cheap and works well.
Old Feb 17, 2012 | 06:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's what the Holley piece looks like.
You bend the two tabs over to lock it on the rod, along with a small bolt.
Old Feb 18, 2012 | 08:20 AM
captain1997
Thanks guys for the help maybe just leave it unhooked and shift it manually when necessary like when im pulling my trailer. Thanks again!
chubrock108
Nov 13, 2009 02:52 AM
ford truck oldboy460
Feb 23, 2009 01:32 PM
btorear
Feb 20, 2009 12:19 PM
trolly79f150
Jun 23, 2003 03:45 PM
JOT
Feb 12, 2002 10:45 PM
