Starting Issues
Old Feb 17, 2012 | 01:58 PM
saxtonj's Avatar
saxtonj
Starting Issues
My '78 F-150 Explorer with 400(214,000 miles) and C/6 has trouble starting after I've driven it a while and it gets operating temp.
When I try to start it it bogs the starter and turns really slow. After several attempts at this it starts normally. If I let it cool off for a while it starts and spins over just fine.
Is this from the cam/crank timing being off(chain stretch)?
I've adjusted the ignition timing(advance and retard) and that doesn't seem to change anything. I have also rebuilt the carb(It did this prior to rebuild).
Anyone have this issue and know what's wrong? Any help appreciated
Old Feb 17, 2012 | 04:36 PM
77393's Avatar
77393
Sounds like the starter might be going out. Have it bench tested, might as well have the battery load tested as well. I would also clean all connections and make sure you set the timing right.
daltonjamesadams
Mar 31, 2017 06:02 PM
88_F0RD
Jan 10, 2017 11:15 PM
1bad67sbf
Mar 13, 2010 07:09 AM
idahofarmboy
May 10, 2008 10:25 AM
grizzley
Apr 3, 2004 02:25 PM
