grinds after starting
Old Feb 17, 2012 | 11:57 AM
Gary E's Avatar
Gary E
Its and 03 ranger with a 4.0 auto and it grinds after starting and it doesn't always start smoothly, like it hops around till it finally starts, kind of like the starter wont disengage. Do I start with a new starter or is more than likely a flexplate issue? I hope its just a starter.
you tube video
2012-02-16_15-35-45_211 - YouTube
2nd problem is it hesitates a second or so before it goes into gear and clicks in hard, kind of like when you are low on oil, but its not low on oil. It also shifts hard. When I got it the column bolts were loose so the shifter was floppy, I am wondering is someone tried to fix it the wrong way. Also now its pretty stiff to move the shifter selector.
also what tranny is in it, it may be some sort of heavy duty unit, it was an x electrical municipality vehicle, it appears to have an 8.8 and heavy duty rear springs.
door tag reads axle rd, tr D, and spr 2c
TIA Guys!
Old Feb 17, 2012 | 01:05 PM
Ford Breakdown's Avatar
Ford Breakdown
I wasn't able to overcome a similar problem on my '86 with an automatic until I replaced the flex plate. It still likes to munch starters, tho. My headaches started after I had the engine and transmission apart from one another. Possibly someone had the engine/transmission split when trying to fix the shifter?
Old Feb 17, 2012 | 01:07 PM
Ford Breakdown
Old Feb 17, 2012 | 01:37 PM
Gary E's Avatar
Gary E
yeah thats what I am afraid of,
the motor is a 4.0 not a 3.0.
Old Feb 17, 2012 | 06:26 PM
Phinxter's Avatar
Phinxter
you might just have a broken spring in the starter, just removing it and checking it is an easy way to tell
Old Feb 18, 2012 | 06:21 AM
03 Maz B23's Avatar
03 Maz B23
The drive gear in starter isn't retracting properly causing your noise. Probably due to a weak spring as stated above. Check your linkages for lubrication for the difficulty moving the tranny gear lever. For the engagement into a gear could be an issue with the valve body/solenoids. How does the fluid look? Might simply indicate the need for fluid and filter change.
Old Feb 18, 2012 | 04:32 PM
Phinxter's Avatar
Phinxter
yeah had a Saturn in the shop and when you took a left turn you would hear a grinding noise. It had me baffled until another guy said he had a truck that did a similar thing and kicked his butt for a couple of weeks and a busted starter spring was the cause, so was the saturn I was working on as it turned out huh!
Old Feb 18, 2012 | 07:13 PM
NS_Andy's Avatar
NS_Andy
Noisy starter, Trans hard to shift
My starter turned out to have some corrosion on the shaft, so that the bendix wasn't retracting once the engine started. Crocus cloth and some grease fixed that. I also had problems shifting from park into other gears, or back into park. Since it's winter and I hate working on my back in the snow, I took my '97 3.0 to a local garage, telling them that it felt like the shifter cable was sticking. It turned out to be the neutral safety switch being just about ready to seize up. They're made from plastic, can't be lubricated, and are attached to the outside of the trans. If you live where winter means lots of salt on the road, this could be part of your problem moving the shifter.
NS_Andy
97 3.0 auto XLT
Old Feb 24, 2012 | 08:06 PM
Gary E's Avatar
Gary E
Sweet it was the starter, The spring felt fine on the old one and it seemed to retract fine on the bench, but it does not do it with the new starter.
The fluid in the tranny looks good maybe too good like someone just flushed it good. It is overfull though when its warm should I drain some out?
There really is no linkage on the tranny but just a cable to the selector lever, I will go out and disconnect the cable to see if it feels like the stiffness is in the lever or the cable.
Old Feb 25, 2012 | 07:59 AM
Phinxter's Avatar
Phinxter
I don't think draining out fluid would help your problem but for peace of mind why not? My guess is your cable or possibly the shifter is causing the stiffness, unless theres a heck of alot of rust on the manual shaft. I'm not familiar with Ford trannys but your harsh engagement sounds like whatever is controlling the pressure inside isn't working so well, might just be a pressure control solenoid or whatever Ford calls that. A pressure test would be a starting point.
TowsonX
May 31, 2017 07:55 PM
sroney
Aug 4, 2014 10:30 PM
77flareside
Mar 5, 2012 02:18 PM
tje2015
27
Jan 24, 2012 07:27 PM
