That awful 1316 code
Old Feb 16, 2012 | 02:23 AM
sambogoode's Avatar
sambogoode
I have narrowed it down to the passenger side connection. Took apart the drivers side earlier tonight, looked good. Made a shim and installed it where future problems wont arise.
There was one bolt that I had a heck of a time getting out. The one behind that rectangular connection on top of the valve cover- it also has the hose that hooks to the turbo inlet. What do you, anyone, use to get that bolt out? Do you loosen the turbo inlet? I need to reinstall tomorrow, hopefully someone has a trick!!
Now that I know its the passenger side, the $180 the dealer wants is starting to sound reasonable.
Thanks in advance,
Sam
Old Feb 16, 2012 | 02:29 AM
BigAlsPSD's Avatar
BigAlsPSD
Are you talking about the bolts behind the crank case vent doghouse? Or the 2 8MM bolts that hold the intake CCV coupler to the mount?
Rectangular connection? The 42 pin electrical plug?
You should have already had the intake tube off all the way back to the turbo inlet, so I am having trouble picturing what you are talking about?
Old Feb 16, 2012 | 02:38 AM
sambogoode's Avatar
sambogoode
I think its the doghouse you mention. Its right on top of the drivers side valve cover. The 13mm bolt is partially behind it. It has a 90degree rubber hose to the turbo inlet. Hopefully that makes better sense.
Sam
Old Feb 16, 2012 | 02:41 AM
BigAlsPSD's Avatar
BigAlsPSD
Remove the 2 countersunk phillips head screws fastening it to the valve cover.
Old Feb 16, 2012 | 03:10 AM
carltonwebb's Avatar
carltonwebb
I used a shorty wrench the second and third time to loosen it and ran it out with my fingers. It was only because i had a really difficult time getting the orings to reseat the first time. I also removed the turbo inlet pipe from the air filter housing all together though. All 3 of those pipes can be taken off in about 10 minutes.
Old Feb 16, 2012 | 10:19 AM
JonathanN's Avatar
JonathanN
A 3/8" ratchet with a 13mm regular socket, knuckle, and extension have worked great for me. As for the plumbing, I usually undo the hose clamps at the turbo and the intake and then unbolt the collar from the bracket. If you have the doghouse set up like it was from the factory, you'll have to unscrew it from the cover and then pull it off. I have the CCV mod so I don't have to worry about the last part.
Old Feb 17, 2012 | 11:54 AM
sambogoode's Avatar
sambogoode
Thanks for the input everyone. I thought there was a way to remove the valve cover without removing the doghouse, turbo inlet, or both. No such luck.
Sam
Old Feb 17, 2012 | 12:03 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Sam
The valve cover will come off without having to remove the doghouse. I usually leave the doghouse attached unless I have spare o-rings handy. Usually once you pull the doghouse, the o-rings won't go back on because they swell to a larger size (or at least that what appears to be happening...)
I think removing the passenger side valve cover is quite a bit easier than the driver's side...
brickie
Jul 19, 2015 10:16 AM
RA31925
WTB - Parts & other
Apr 19, 2013 04:06 PM
Jrex1233
Nov 5, 2012 05:22 PM
jacksonford
Mar 6, 2009 07:11 AM
ram2miller
Nov 5, 2006 09:05 PM
