Injection Pump gear Tooth Count
Old Feb 15, 2012 | 09:48 PM
jaluhn's Avatar
jaluhn
How many teeth are on the injection pump gear? I think it's 102 or 110 but don't have one to check. I need to know to calibrate my tach.
Thanks,
~John
Old Feb 15, 2012 | 10:05 PM
rhkcommander959's Avatar
rhkcommander959
definitely close. for some reason i wanna say 106 though. Was just wondering this myself today
Edit: I was right. 106
http://www.oilburners.net/forums/showthread.php?t=30492
What tach you got?
Old Feb 16, 2012 | 10:04 PM
jaluhn's Avatar
jaluhn
Thanks. I counted when i had the engine apart but apparently forgot to write it down. Dope!
I've got an ISSPRO 5585 on order, 3 3/8" EV programmable 3500 RPM tach. I've got a 3 3/8" speedo, 2 5/8" EV electric oil pressure, water temp & oil temp, and 2" pyro, boost, fuel, volts, all ISSPRO. The tach was the only stock gauge I was still using. I'm in the process of making a custom gauge cluster to put my tach, speedo, oil press, water temp, volts and fuel in place of the stock cluster. If I can get it to work the way i want I think it'll come out pretty nice.
wiesman2613
Aug 30, 2012 05:55 PM
griiz
Jul 22, 2009 06:10 PM
924x2150
Aug 10, 2005 07:48 PM
oldcoupe42
Dec 13, 2003 06:09 PM
