I have a 95 F150 extended cab I-6 engine and was wondering what the blank gauge panel is for (located directly to the right of my fuel gauge, not with the rest of the gauges, but by itself)
Thanks in advance
chet, do you have a tach? mine is a 89 and it looks like this:
Battery(top left), Fuel(Lower Left), Oil(next to the batt.), and then temp.(next to the fuel) but and then my speedo, and then the tach. So it all matters if you have a factory tach, or not
Can you post a pic? This generation of F-Series had tach as optional. Without tach the guages were split 2 to the left [oil/temp] of the speedo & 2 to the right [volts/fuel]; with tach (to right of speedo) all four were left of the speedo.
