will this cause a fire???
Old Feb 15, 2012 | 06:42 PM
rhino_160's Avatar
rhino_160
Ok i have a 2000 Navi and i bought the silverstar 9005 65watt bulbs for the foglights. i have found the bulbs will not fit the factory plug but i found a plug that will. if i tie in the new plug will this cause a problem being the old bulbs were like 25watt and the new are 65??? thanks
Old Feb 15, 2012 | 07:15 PM
alwaysfords41's Avatar
alwaysfords41
9005 is a headlight bulb isn't it? That is why it is 65 watts vs whatever was in the fog light assembly. You are likely to melt the lens if that is the case.
Old Feb 15, 2012 | 07:30 PM
rhino_160's Avatar
rhino_160
there are several people on here that say they have converted their expedition fogs to the 9005. i didn't know the plug were diff on a navi and expi. i was hoping a Navi owner could chime in. if not, i will be selling a brand new set of 9005 Ultras
Old Feb 15, 2012 | 08:56 PM
alloro's Avatar
alloro
You're going from about 2-amps per light to about 5.5-amps per light. You run the risk of blowing the fuse because of the increased 7-amp load, but more importantly as alwaysfords41 pointed out, the extra heat can cause some melting
Slippery750
Feb 24, 2017 06:14 PM
fordf2501
Sep 16, 2016 12:25 AM
rhino_160
Feb 16, 2012 07:35 PM
ExcursionUSA
Oct 29, 2011 06:38 PM
snakedoc
May 5, 2010 10:29 PM
