Sorry Bruno. Didn't mean to steal your thread with our comparison.
As to what lebaron said, that would be the best way to do it. If you really get a wild hair you can check your camber and toe yourself with a Longacre gauge:
The tires on my truck appear to have too much camber, they lean out slightly and they wear on the outer edge. However I got to looking at everything more and I can see that the tires have too much toe in. After replacing the balljoints on one side and finding out that I have "0" degree bushings; I half way came to the conclusion that the toe in is pulling the tires in at the pavement causing the camber to look out of wack.
