glow plug change?
Old Feb 13, 2012 | 06:23 AM
Liquid10Rider's Avatar
Liquid10Rider
glow plug change?
Hey guys I asked my local ford dealer when to change your glowplugs but they wont tell you anything. Im at 105K and the PO didnt say anything about that he had changed them. When I bought the truck it had 72K on it.
Thanks,
-AJ
Old Feb 13, 2012 | 06:56 AM
woodnthings's Avatar
woodnthings
Changing them is considered good routine maintenance. It wouldn't hurt to change them now with OEM glow plugs which are the Motorcraft ZD-11's. Only use them as the other brands are not so good.
It is also a great time to inspect the valvetrain and retourque everything. Also you should do the fifty cent mod to the UVCH.
Performing that will keep the truck running great and will keep you out of the shop and off the side of the road for any of the normal no start or UVCH issues.
Old Feb 13, 2012 | 09:01 AM
01PS's Avatar
01PS
After what I found on my UVCH this weekend I urge you to do this. I had 5 bad GPs and a badly burnt valve cover gasket and UVCH on the passenger side. Both plugs were backed out so 50 cent mod was done at the same time. This repair also made me notice my leaking fuel bowl and my turbo seeping oil.
Old Feb 27, 2012 | 03:55 PM
MikeSDK's Avatar
MikeSDK
Where can I find info on the 50 cent mod, what it is and how to do it?
I didn't see it in the common mods sticky-
Thanks
Old Feb 27, 2012 | 06:46 PM
Gruntface's Avatar
Gruntface
I called the other day to my Ford dealer and the parts guy said you should change the glow plugs when they go bad, one at a time style. However, he also said the mechanic that does the changes for customers as needed, changes all his glowplugs in his 7.3 every 100,000.
I have read about these dual coil glow plugs but seems they are for older 7.3 like pre psd 7.3s. Can I get the motorcraft/beru dual coil glow plugs for my 2001?
Old Feb 27, 2012 | 06:50 PM
woodnthings
Thanks
Here you go.
https://www.ford-trucks.com/forums/9...-cent-mod.html
Old Feb 27, 2012 | 07:33 PM
Liquid10Rider
Does anyone know where I coud find the full write up of the 50 cent mod? And possibly the other parts that are needed besides the valve cover gaskets. And how lopng does it usualy take to do this job?
Old Feb 27, 2012 | 09:50 PM
texas5.0's Avatar
texas5.0
When I changed mine out I took my time and took around 5 hr or so with lunch and all I just reused my valve cover gaskets
these 2 post helped me a bunch
https://www.ford-trucks.com/forums/1...low-plugs.html
and
https://www.ford-trucks.com/forums/9...-pictures.html
Old Apr 6, 2012 | 04:00 PM
Liquid10Rider
is it ok to use dielectric grease on the VCH plug on the outside of the VC? and also for the big black and red plug with screw in the center? I would think so but just want to make sure before i do something that could mess something up
thanks,
-AJ
Old Apr 6, 2012 | 06:39 PM
Shake-N-Bake's Avatar
Shake-N-Bake
thanks,
-AJ
I greased up those connectors several years ago and haven't had any issues. This is the stuff I used
Electrical Grease
Per Ford's instructions, I smeared it liberally all over the connector and pins and re-assembled. Seemed odd to me but if you read their tech papers that is how it's supposed to be used. I've pretty much used it on every electrical connector in the engine bay and the engine runs very smooth. Of all my trucks, this one runs the best.
NMRider
Jul 1, 2012 06:52 PM
crstewart60
Dec 27, 2011 12:41 PM
captjack
16
Oct 31, 2011 10:04 AM
bearhugger
Apr 24, 2010 09:15 PM
WALJON
Oct 14, 2007 12:42 AM
