NUMBER DUMMY
Old Feb 12, 2012 | 09:56 PM
wdmack's Avatar
wdmack
NUMBER DUMMY
How do I ID my 223 motor and 3 speed manual transmission. I have both out of truck. Someone told me they looked in there shop manual and it did not give answer
Old Feb 13, 2012 | 01:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your profile says 1964 F100, so I assume this is the truck you're asking these questions about, but for what reasons do you need to ID either?
The 223 I-6 was basically the same 1961/64 F100/600. 1963/64 F100/250's came standard equipment with the Ford 3.03 3 speed manual all syncromesh transmission.
3 speed Warner T-86 overdrive was optional in 1961/64 F100's.
Old Feb 13, 2012 | 06:50 AM
wdmack's Avatar
wdmack
Number I just want to make sure it is the 223, Because the guy told me his father had some major work done to the motor some years back. I dont even know if its a 223 but I think so. Thanks David Mack
Old Feb 13, 2012 | 12:52 PM
kjvforme's Avatar
kjvforme
What side is the intake manifold on?
Old Feb 13, 2012 | 01:40 PM
NumberDummy
The 4th digit of the VIN is the engine code:
J = 223 I-6 / B = 262 I-6, which was an option for 1961/64's.
But, who knows after 48 years have passed by, what engine is present today?
Both the 223 & 262 look identical, share many of the same parts, so the only true way to tell one from the other is by measuring the stroke.
Stroke: 223 = 3.60" / 262 = 4.03"
Old Feb 13, 2012 | 10:29 PM
kjvforme's Avatar
kjvforme
I was thinking someone threw in a 300 I-6 Bill.
Old Feb 14, 2012 | 02:24 AM
NumberDummy
I assumed that's what you were referring to when you asked what side the manifolds were on.
Old Feb 14, 2012 | 06:54 AM
wdmack's Avatar
wdmack
Manifold on left side. WHich just to clarify I do consider drivers side. Thaere is a shutoff valve on thermostat housing is that oe. David
Old Feb 14, 2012 | 07:02 AM
NumberDummy
Everyone else considers it the drivers side, except for peeps that live in countries where they drive on the wrong side of the road.
Examples: Australia, Japan, India, Indonesia, South Africa, New Zealand, UK
Old Feb 14, 2012 | 12:55 PM
garbz2's Avatar
garbz2
Pull number one spark plug and measure the stroke with a wooden dowel by turning the engine over by hand one full rev.
Garbz
66low
Dec 29, 2014 12:04 PM
mngriz
Oct 17, 2014 12:54 PM
Mikulh
Dec 15, 2011 10:53 AM
Mosch1
Oct 21, 2006 02:04 PM
83f100ss
13
Jan 11, 2004 11:26 PM
