83 F100 Stepside Info needed!
Old Jan 6, 2004 | 11:31 PM
83f100ss's Avatar
83f100ss
Does anybody know what transmission and rear end's came in the 83 F100 stepside trucks with the 4.9L engine?
Old Jan 7, 2004 | 09:22 AM
cdd5599's Avatar
cdd5599
Do you know if is a manual or automatic?
Old Jan 8, 2004 | 04:06 PM
83f100ss's Avatar
83f100ss
automatic
Old Jan 8, 2004 | 04:10 PM
BlueOvalboy25's Avatar
BlueOvalboy25
My 1984 has a four speed manual
Old Jan 8, 2004 | 04:35 PM
acerockola77's Avatar
acerockola77
3 speed automatic? That would be the C6.
Old Jan 8, 2004 | 04:57 PM
83f100ss's Avatar
83f100ss
it's a 4-speed auto, and do you know what rear ends came in these trucks?
Old Jan 8, 2004 | 05:09 PM
82F100SWB's Avatar
82F100SWB
Get the axle and transmission codes off of the door tag and post them here.
Old Jan 8, 2004 | 11:30 PM
GypsyR's Avatar
GypsyR
If it's a 4 speed automatic then it's an "AOD".
Stick you head under the rear bumper and look at the big center part of the rear axle. If the center part has a cover that's bolted on all around, then it's an "8.8 inch". If what you see has no circle of bolts and is just a rounded bulge then it's a "9 inch".
If you see a metal ribbon tag hanging on one of those bolts (you'll have look at the fronside of the axle if it's a 9") crawl under for a closer look. If it's readable, look at the second line, it will have numbers something like "3.L73 8.8 abc" (3.73 ratio limited slip 8.8") or "3.08 9abc" (plain 3.00 ratio 9"). The "abc" is just an example for the date code or whatever else is on there too.
Don't be surprised if the tag is missing or unreadable due to rust, the truck is 20 years old after all.
Ratios found in 83 F150's are :
2.47,2.75,3.00,3.25,3.50, and 4.11 for the 9 inch
and
2.47,2.73,3.08,3.55, and 4.10 for the 8.8's
Old Jan 8, 2004 | 11:34 PM
83f100ss's Avatar
83f100ss
thanks for the info fellas
Old Jan 8, 2004 | 11:38 PM
83f100ss's Avatar
83f100ss
Do you think it could be posi trac?
Old Jan 10, 2004 | 05:25 PM
83f100ss's Avatar
83f100ss
My axel code is 18, and transmission code is T.....
Old Jan 10, 2004 | 10:32 PM
82F100SWB's Avatar
82F100SWB
You have a 3.08 geared, open 8.8" rear diff, and an AOD transmission
Old Jan 11, 2004 | 02:44 PM
83f100ss's Avatar
83f100ss
what is an open differential?
Old Jan 11, 2004 | 11:26 PM
GypsyR's Avatar
GypsyR
NOT a posi, traction lock, locking or fancy rearend. Just the plain-jane standard rear end.
