56 Vent window handle and latch
Old Feb 12, 2012 | 07:31 PM
hooler1's Avatar
hooler1
I'm trying to repair my driver's side vent window latch on my '56 F-100. It was stuck and would not move. So with a rebuild kit from Mid 50's I was going to take it apart today. And try it with out removing the vent window. While putting a piece of 1/2" rubber hose under the latch for support, I took a slide hammer and a 3/32" punch, and I was able to drive out the roll pin that runs thru the handle, and you would think the rest of the handle would would just pull off the shaft going to the vent vindow, but for the life of me, I can not get the handle to pull off, even though the handle now moves, but does not latch. Is there anything I am missing in order to pull the handle off? I used lots of WD-40, gentle pulling, prying, but it will not pull off the shaft.
Old Feb 19, 2012 | 09:21 PM
hooler1's Avatar
hooler1
I finally got it. I just heated up the handle with a heat gun. It sliped right off. What was holding it on? You guess it...a rusty shaft! I took took some scotch brite, rubbed off the rust, and put it all back together. It works great!
abyars111
Apr 17, 2015 12:28 AM
GreatNorthWoods
Jul 9, 2012 04:08 PM
scottddove
Nov 17, 2008 11:52 AM
vanwho
Feb 23, 2006 05:55 PM
bigric
Oct 22, 2004 07:47 AM
