vent window latch
Old Apr 16, 2015 | 01:50 PM
abyars111's Avatar
abyars111
vent window latch
I want to change the latches on my vent windows. I have knew latches. Does someone know of a trick to remove the old latch? I can't get the roll pin in the old latch to budge.
Old Apr 16, 2015 | 02:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are no vent frame latches, just handles.
1968/72 F100/750's use the same vent frames and handles / 1967 F100/750 vent frames and handles are 1967 ONLY!
Old Apr 16, 2015 | 02:21 PM
ultraranger's Avatar
ultraranger
That's something I would like to know too.
I've been eyeballing the later model F150s with a vent window. They have a latch built into the lever arm pivot. If their post diameter and lever offset is the same, I would like to adapt them over onto my truck, to have a locking vent window latch.
Old Apr 16, 2015 | 02:25 PM
JEFFFAFA's Avatar
JEFFFAFA
I've never had the pleasure Aby. If I were to do it I'd have the window unlatched. Keeping tension off the handle and it's roll pin. And I'd grind an old punch down to the diameter of the roll pin and use it to tap the old pin out.
Old Apr 16, 2015 | 02:31 PM
JEFFFAFA's Avatar
JEFFFAFA
It's been billions of years since I eyeballed this stuff but if I remember right the locking handles/pins/springs off a Dent will work on a Bump vent window frame. I've never tried it but I remember thinking it would work. Caution, this is going back Decades though. Going to a JY and trying it 1st would be a good idea. If ya go to a JY and can swap the stuff out (without buying anything yet) let me/us know.
Old Apr 16, 2015 | 02:42 PM
JEFFFAFA's Avatar
JEFFFAFA
I better mention this also. I just checked Dent stuff. In 1977 when Ford changed from a non-locking handle to a locking style they also changed the vent window frame. So I think a locking Dent handle will fit on a Bump frame but I think a flat spot would have to be ground in the handle's shaft for the release pin to be able to move and work.
Ford lists the same non-locking handles C8OZ5422916B and C8OZ5422917B fitting 68/early 77 Bumps and Dents.
Old Apr 16, 2015 | 02:44 PM
abyars111's Avatar
abyars111
NumberDummy is right, vent handle. I forgot to mention this is on a 1970 model. I'll try soaking them with some WD40 and grind down a punch. I'll try cutting a block of wood to wedge between the bottom of the vent handle and door to steady it up. I bought my handles from Dennis Carpenter.
Old Apr 16, 2015 | 02:45 PM
NumberDummy
C8OZ-5422916-B Right & C8OZ-5422917-B Left .. Vent Frame Handles / Obsolete
1968/76 F100/750 / 1977 F100/750 before serial number Y00,001 // 1968/77 Bronco // 1968 Mustang/Cougar / 1968/70 Falcon / 1968/71 Fairlane/Torino station wagons.
C8UZ-8922916-A Right & C8UZ-8922917-A Left .. Vent Frame Handles-Brite finish / Obsolete
1977 F100/350 from serial number Y00,001 // 1978 Bronco before serial number BJ0,001 // 1969/74 E100/300 / 1975/78 E100/350.
D8UZ-1122916-A Right & D8UZ-1122917-A Left .. Vent Frame Handles-Black finish / Available from Ford.
1978/79 F100/350 / 1978 Bronco from serial number BJ0,001 / 1979 Bronco / 1979/84 E100/350 / 1985 E100/350 before production date 11/84.
C8TZ-8121608-A Right & C8TZ-8121609-A Left .. Vent Frames / Obsolete
1968/72 F100/750.
D3TZ-1021608-A Right & D3TZ-1021609-A Left .. Vent Frames / Obsolete
1973/76 F100/750 / 1977 F100/750 before serial number Y00,001. I have a NOS left side, it's black.
D7TZ-1021608-A Right & D7TZ-1021609-A Left .. Vent Frames / Obsolete
1977 F100/350 from serial number Y00,001 / 1978/79 F100/750 & Bronco.
Old Apr 16, 2015 | 03:35 PM
Randle's Avatar
Randle
When I changed mine I ground the point off of a finishing nail and held the nail with a pair of of vise grips to drive it out.
When I restored a 76 a few years back I robbed a pair off of a 71 I parted out to go on it.
Old Apr 16, 2015 | 03:48 PM
abyars111's Avatar
abyars111
[QUOTE=Randle;15276268]When I changed mine I ground the point off of a finishing nail and held the nail with a pair of of vise grips to drive it out.
Thanks, I'll give that a try.
Old Apr 16, 2015 | 05:24 PM
Uni Moe's Avatar
Uni Moe
While we're on the subject, my driver side handle is a bit wobbly worn. I'm wondering if a replacement handle will fix the problem or is it the pin on the frame that will be worn? Or both?
Old Apr 16, 2015 | 05:39 PM
JEFFFAFA's Avatar
JEFFFAFA
Prolly the handle Uni. The pins on those frames always looked like hardened steel to me.
Old Apr 17, 2015 | 12:28 AM
orich's Avatar
orich
The latch handle is made of much softer metal as, I found out when changing mine out about 5 yrs ago. Though the same thing will it be a waste or a fix.
It was a fix for loose sloppy wind wing latch handles..
Orich
Brittanysmith
Mar 3, 2017 10:28 AM
ghostwhite
Oct 15, 2010 09:26 AM
75F100GA
16
Jan 25, 2007 08:07 PM
deisele75
Dec 15, 2005 09:28 PM
bigric
Oct 22, 2004 07:47 AM
