Distributor Help
Old Feb 12, 2012 | 06:00 PM
billslk32's Avatar
billslk32
Distributor Help
I have a 1961 Ford F100 Unibody Custom Cab Original 292 3 speed. The distributor is marked COFT-12127B. Is B9FA-12127A Compatible? They look identical?
Thanks...
Bill.
Old Feb 14, 2012 | 04:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by billslk32
I have a 1961 Ford F100 Unibody Custom Cab Original 292 3 speed. The distributor is marked C0TF-12127-B.
Is B9FA-12127-A Compatible? They look identical?
Looks can be deceiving.
Marked: C0TF-12127-B = Ford part number: C0TZ-12127-J (replaced C0TF-12127-B) .. 292 2V Distributor / Obsolete
Edit: C3TZ-12127-K replaced C0TZ-12127-J
Applications: 1960/64: F100/700 / C550/700 / P350/500.
Marked B9FA-12127-A = Ford part number: B9A-12127-B .. 292 2V Distributor.
Applications: 1958/59 Ford Passenger Cars.
Make sure the B9 tag reads B9FA not B9AF / B9AF is a 332/352 FE distributor.
Last edited by NumberDummy; Feb 14, 2012 at 05:02 AM. Reason: *&(^&*^&% Ford changed the part number!
Old Feb 14, 2012 | 04:28 AM
billslk32's Avatar
billslk32
Thanks Bill. Are there any NOS truck ones around?
Bill.
Old Feb 14, 2012 | 04:44 AM
NumberDummy
I made some changes to the above post, because...
FoMoCo is in-famous for replacing 10's of 1000's of part numbers EVERY YEAR!
C3TZ-12127-K = replaced C0TF-12127-B & C0TZ-12127-J
No Ford Dealer or obsolete parts vendor has C3TZ-12127-K or C0TZ-12127-J
C0TF-12127-B =
ANTIQUE AUTO SUPPLY in Arlington TX has TWO = 817-275-2381.
Old Feb 14, 2012 | 04:45 AM
billslk32's Avatar
billslk32
Thanks again Bill.
Old Feb 14, 2012 | 05:06 AM
NumberDummy
Thanks again Bill.
Found two of the puppies NOS, see post #4
Note: C0TF-12127-B is the original ID and part number.
Doubleclutch
Jan 23, 2016 09:01 AM
GVA66FordF100
Apr 19, 2013 03:16 PM
Beatles65
Mar 2, 2010 03:13 PM
duhrbroc
May 31, 2009 11:17 AM
mark_the_redneck
13
Nov 5, 2004 09:03 AM
