Spare Tire
Old Feb 12, 2012 | 04:02 PM
midsouth's Avatar
midsouth
Spare Tire
On a 1983 f150 4X4, where is the spare tire stored? Is the spare a doughnut or full sized tire and rim?
Old Feb 12, 2012 | 04:12 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Factory location (if equipped, it was an option) was underneath the box.
But if bed space isn't a concern, they sell a in-bed mount for it, mount it standing up on the side.
I preffer having it underneath though, I like bed space.
Old Feb 12, 2012 | 04:13 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I just leave mine in the bed.
It hasn't been stolen... yet.
Old Feb 12, 2012 | 04:15 PM
IDIDieselJohn
Something to do to keep midnight pickers away, just have it be an old really worn out tire, with a rusty rim. No one wants those
Old Feb 12, 2012 | 04:52 PM
midsouth's Avatar
midsouth
Would I mount it under the gas tank? Unfortunately I don't see a place where it used to be. Do I need to look for a full size tire and rim?
Old Feb 12, 2012 | 05:04 PM
f100beatertruck's Avatar
f100beatertruck
I would use a full size tire, especially if you have a limited slip diff. If you have wide off road tires you can get one that's the same diameter but more narrow. This assumes they're a reasonable diameter... I don't think 44's are going to fit under there...
There's a bar that hooks up in one corner, drivers side front and goes cross ways to the passenger side rear. It's hooked in the front, the tire's put on then you lift it in the rear and attach it.
Yes, it mounts under the rear tank.
Old Feb 12, 2012 | 05:06 PM
midsouth's Avatar
midsouth
Thank you for the information. Will the dual exhaust be a problem?
Old Feb 12, 2012 | 05:13 PM
IDIDieselJohn
That depends on your exhaust, how it was fitted.
Old Feb 13, 2012 | 12:25 AM
kedwinh's Avatar
kedwinh
Mine didn't come with one under the bed. So my cousin and I mounted one from an import truck, cant remember what make, and welded it up to the frame under the rear of the bed. Kind of nice, just pull the crank out and crank it down. Unhook the chain from it and done. Works great.
Old Feb 13, 2012 | 08:41 AM
f100beatertruck
I finally got my 86 last night and it's got the underbed carrier with no tire in it. I can take pictures later so everyone can see. It also has the rear tank.
Old Feb 13, 2012 | 08:45 AM
Grubbworm's Avatar
Grubbworm
I just posted some pictures of how my spare tire is attached here on this thread; https://www.ford-trucks.com/forums/1...-required.html
I hope this helps some. if not, let me know and I will take some more pictures.
Old Feb 13, 2012 | 01:03 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
These trucks came with a standard spare tire carrier under the bed. If the truck came without a spare tire being ordered from the factory a two piece block of wood was installed in location of the tire. This was a simple carrier with a bolt on one side and an eye bolt on the other.
There were two optional spare tire carriers making a total of three with the standard one.
The slide out spare tire carrier was and option, also located under the bed. It had a handle that you could rotate, unlock and pull the spare out from under the truck.
The In-Box spare tire carrier was located in the bed and bolted to the side of the bed either on the driver's side left front, or passenger's side right rear.
All versions had provisions for optional locking.
Old Feb 13, 2012 | 01:08 PM
Fordzilla80's Avatar
Fordzilla80
I have, well had the in-bed mount on my truck. You can clearly see the holes in the bed for the bolts. A previous owner was nice enough to take the actual mount bracket out, but he was nice enough to leave the bolts.
Fastolds
Apr 26, 2018 08:07 AM
SwampFox112
19
Jan 30, 2016 01:47 PM
slayer61
Dec 20, 2010 10:23 AM
jakeman203
Feb 3, 2010 11:18 AM
lewmon
15
Oct 1, 2001 10:38 AM
