spare tire options?
Old Apr 22, 2018 | 09:05 AM
Fastolds's Avatar
Fastolds
spare tire options?
What options are out there for mounting a spare tire? In the factory location and bed mount are the only ones I see. I have been contemplating finding a setup with a hoist, like my 4runner or basically anything newer.
Anyone done something like that so I can copy?
Old Apr 22, 2018 | 02:06 PM
FuzzFace2's Avatar
FuzzFace2
There has been talk of using the newer winch type but that is all I have seen post just talk so don't know if it has ever been done?
Anyone done it and got pictures and a how to?
Dave - - - -
Old Apr 23, 2018 | 01:54 PM
Megiddo's Avatar
Megiddo
If you are getting rid of your OEM behind the rear axle carrier, let me know. My spare is just in the bed right now.
Old Apr 24, 2018 | 08:14 AM
1986F150six's Avatar
1986F150six
Old Apr 24, 2018 | 10:09 AM
Megiddo's Avatar
Megiddo
Thanks, I wish I would have seen that when it was first posted. I have been watching e-bay for one for a few weeks with no luck. Its nice to have the OEM part numbers, though.
Old Apr 24, 2018 | 12:23 PM
DOOD95's Avatar
DOOD95
My personal favorite is swapping a Bronco swing-away spare carrier onto the back of an F-150. I am going to be doing this swap on '85 longbed in the near future. I saw a guy that had put a front hub on the carrier so he had an extra hub should he need it out in the wild as well. (Mine's a 2wd so that wouldn't be a great idea for the F-150 but I am considering it on my Bronco...)
Old Apr 25, 2018 | 08:08 AM
Olds64's Avatar
Olds64
You could go old schcool and mount it up front. It would make it easier if you had a bull bar or brush guard.
There are also replacement tailgates that the "off-road" crew uses to store the spare tire and a jerry can.
Old Apr 25, 2018 | 06:01 PM
kr98664's Avatar
kr98664
I had that arrangement for several years. Even had the tire cover with ducks in it, similar to this:
https://tirecovers.com/ducks-in-flight-tire-cover.html
Went great with my sandals and black socks, too. I was styling.
Alas, the location caused overheating on hot days. I had to scrounge up a factory set up and mount the spare under the rear gas tank. No more overheating.
One thing to consider is how often have you needed the spare? In 25 years, my truck has had exactly one flat. Even with the later model winch set up, you're still going to get plenty dirty changing a flat. You're not going to get that much dirtier wrestling a tire to the ground from an earlier carrier.
Old Apr 26, 2018 | 07:48 AM
Olds64's Avatar
Olds64
Very true. Right now my truck doesn't even have a spare. I need some missing parts for my spare tire carrier. Let's hope I don't need one.
I thought of mounting it up front because I drove a Dentside as a teenager at Scout Camp. It had the spare mounted up front. Of course, we always just puttered around so there wasn't much chance of over heating.
Old Apr 26, 2018 | 08:07 AM
ozark1's Avatar
ozark1
I think I'm the only one that likes my setup...(Do a search for pictures)..but I used a BAJA mount up next to the front of the bed. Tire is at an angle..easy in and out. takes up some bed space..but..when is last time you used the entire bed floor ??
SwampFox112
19
Jan 30, 2016 01:47 PM
midsouth
Feb 13, 2012 01:08 PM
79FordBlake
20
Dec 20, 2010 10:31 AM
PassedDown66
May 26, 2010 10:27 AM
GolferSA
May 4, 2002 11:36 AM
