hard starting
Old Feb 12, 2012 | 10:44 AM
wdonohoe1's Avatar
wdonohoe1
hard starting
I have a 91 7.3 that won't start without sterting fluid. glow plugs and controler works fine I put new batt cables on. starter tests fine it runs fine after i start it with fluid
Thanks Bill
Old Feb 12, 2012 | 12:32 PM
IDI guy's Avatar
IDI guy
Thanks Bill
I am guessing you are talking about starting fluid you may have one of several problems, your batterys may not be putting out enough amperage, you could have air leaking into tour return lines, your glow plugs could be no good. If you have to crank it over a bunch to start it it is probably is the returnn lines, the excessive cranking can cause your starter to burn up so don't do it. Starting fluid coming into your engine on the intake stroke can hit your hot glow plugs and explode causing bent rods berrings damage to your pistons so if you absolutely have to use starting fluid disconect all of your glow plugs first or you might be looking for a new engine. The fuel return lines run between the injectors and they need to be replaced from time to time because as they wear out they start to leak air, they won't usuallt leak fuel though, when the truck is sitting over night those lines will leak air into you fuel injection system when you try to start the truck you will not get fuel to all 8 cylanders and it will usually spit out white smoke untill all of the air is purged then it will start. Replace your return lines FTE member typefour has kits that are better than anyone elses and are quite a bit cheeper than the napa kits. Try that.
Old Feb 12, 2012 | 12:39 PM
IDIDieselJohn's Avatar
IDIDieselJohn
How long is the Wait To Start Light staying on for? Minimum is 10 seconds it should stay on.
Do you hear the relay clicking after the cycle like it should?
Is your lift pump putting out enough pressure? (I think 7psi).
Old Feb 12, 2012 | 03:26 PM
Aune163rd's Avatar
Aune163rd
x2 with what john said...in my expierience, the lift pump will last forever...or last two weeks....then die...
Hudsoner
Jul 22, 2015 08:09 AM
blazinjames
Jan 28, 2012 08:58 PM
rpf27
Jan 27, 2008 09:02 PM
Liftech
Sep 12, 2007 06:34 PM
rdmytro
Jan 8, 2007 03:17 AM
