No Start 86'
Old Dec 29, 2006 | 10:37 AM
rdmytro's Avatar
rdmytro
No Start 86'
On Tuesday I purchased an 88' F250 with a 6.9L. The truck started up and drove fine at the previous owners, and made the 50 mile trip home with no problems. But on Wednesday morning the truck wouldn't start. Since then, I replaced the glow plugs - three of the eight had resistance greater than 2 ohms, and still it won't start.
I am guessing from reading the other posts that I have a air leak. What is the best way to start determining where the leak is?
Old Dec 29, 2006 | 10:57 AM
harleyjohn45's Avatar
harleyjohn45
if your truck has a mechanical fuel pump and you have old any kind of an air leak, it will not start. i use an electric pump and let it run a few seconds before cranking. i know my truck has air leaks, and i plan to fix them all next summer.
Old Dec 29, 2006 | 11:22 AM
bc6.9's Avatar
bc6.9
All 8 glow plugs replaced? If not they should all be replaced at the same time. Air in the system can be a bitch to figure out....
-if the return lines are original [painted grey] replace them with a return line kit
-on the fuel filter head, there is a shrader valve...push it in while the engine is being cranked to bleed the air out of the system
-do not crank the starter for more than 30 seconds [cool down for 2 to 3 minutes] at a time or it will damage the starter
-if you have a block heater, use it, this will help starting it up
-the # 1 injector has a fuel return line to the fuel filter, this can drain the lines causing air in the system. To fix this, cut and plug each end.
I hope this helps, we all have had starting problems of one kind or another....I have just pointed out a few solutions to what may be your problem, there are many more, the trick is figuring out what the problem is, lol.
Old Dec 29, 2006 | 12:02 PM
rdmytro's Avatar
rdmytro
Thank for your help.
All eight glow plugs were replaced with new Motorcraft glow plugs.
The return lines are black with a cloth covering.
Once I get the truck running should I reconnect the return line from the number one injector to the fuel filter?
Old Dec 29, 2006 | 12:41 PM
bc6.9's Avatar
bc6.9
If that is where the air intrusion is happening...no, keep it plugged....another common problem is the orings.
Old Dec 29, 2006 | 03:23 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
One other place to look is: check the fuel lines from the tank to the engine. I had one which was rusting badly under a hold down clip to the frame. Repaired that section and haven't had a problem since.
Old Dec 29, 2006 | 03:34 PM
rdmytro's Avatar
rdmytro
I cut and plugged the lines. All of the fuel is coming out of the filter head with no bubbles. Still no luck.
How quickly should fuel be coming out of the fuel filter head and at what pressure?
Is their anything else I should check?
Old Dec 29, 2006 | 04:26 PM
bigredtruckmi
Veteran: Navy
undo the fuel line from the IP. Coming from the filter. Wonder if cripped/collapsed inside or blocked.
Old Dec 29, 2006 | 09:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
5 to 7 PSI for pressure checked at the schrader valve with the core removed and all the lines hooked up.
1/3 pint of fuel in 10 seconds of cranking the engine at the same location.
If either of these numbers are low, you either have an air leak in the main fuel line from the tank or a bad lift pump.
Old Dec 29, 2006 | 11:20 PM
rcraig's Avatar
rcraig
Be sure your getting 12 volts to the IP. Your engine may be turning over but the Injection pump isnt letting any fuel into the injectors. With the key in the on position use a test light and see if you have power at the IP. If not use a jumper from the battery make it hot and try starting it. if thats it be sure to remove the jumper or you wont be able to turn the motor off with the ignition key.
Old Jan 8, 2007 | 03:17 AM
rdmytro's Avatar
rdmytro
Starting Againg
I cleaned up the battery terminals and recharged both batteries and the the truck started without any issues. I guess it was a combination of air in the fuel and a low battery voltage.
