DOT weights. What is ticketable?
NCDOT: Commercial Drivers (CDL)
- Any combination of vehicles with a gross vehicle weight rating (<abbr title="Gross Vehicle Weight Rating">GVWR</abbr>) of 26,001 pounds or more
- <abbr title="Gross Vehicle Weight Rating">GVWR</abbr> of towed vehicles is in excess of 10,000 pounds
■Any single vehicle with a GVWR of 26,001 pounds or more
■Any vehicle towing a vehicle with a GVWR not in excess of 10,000 pounds
Either way it's based on GVWR, not what your trailer weights loaded.
Do not go over axle ratings or tire ratings.
Depending on state, make sure registered weight is also not exceded.
Note that the commercial enforcement police will not pull over a private truck unless it is really out of shape, but a regular state patrolman will, and then call in a "expert" at his or her discression to "assist".
So, that said, in Washington state, the easy way is to take the GVWR of the truck, add the GVWR of the trailer, and license the truck for that. Of course if you know that you will NOT fully load your truck/trailer, then you can buy a tonnage license for less that what the two add up to, IE a lot of the 8600/8800 GVWR trucks carry a 8000 license. Of course that negates the whole purpose of buying a heavier duty truck, the ability to use the full capacity available! And, as well those same trucks can / will pull a trailer which makes them illegal, as they have not paid tonnage fees on the trailer, but most of the time the private guys can skate by, unless the state is looking hard to make money, which happens at known times of the year when private trucks have a known track record of being illegal / overloaded / makes fiscal sense because they can pull a whole lot of trucks over in a short period of time - Firewood season!
IE if you have a 8k truck and a 10k trailer, then your truck, private or commercial MUST be licensed at 18k, if you fully load them! to GVWR's The state of Washington does not charge tonnage fees on trailer so the the way they collect the fees on the trailer weight is on the truck license.
Please note this is Washington state, your state may be different. Remember though, this has nothing to do with what your LEGAL and binding safety certificate lists for the trucks GAWR's and GVWR (and the trailers). You can license a two axle 1/2 ton truck for 34,000 lbs, the state is more than happy to take the extra fees, but go thru a scale overloaded (over the legal GAWR's and GVWR), or one of the portable scales they set up to catch the overloaded PRIVATE users hauling there firewood and you will be ticketed and forced to make the truck safe and legal before further travel is permitted.
As a side note, I used to follow the portable scales and pick up the firewood that the private persons had to unload / discard because they were overloaded. I heated my house for only some time and fuel costs for several years!!
As i have mentioned, the gray area is the RECOMMENDED GCWR of your truck. While not legaly binding and in this state and you cannot be ticketed directly for excedding this recommended number (only the GAWR's and GVWR's), if you have a accident and you have exceded the recommendations, and this had a part in the cause of the accident, then you can be ticketed. Your insurance also will have a problem if you are towing outside of either the legal limits or the recommended limits.
Washington state also goes in 2000lb increments, so in the case of that 8600/8800 GVWR truck, it is either a 8000lb or 10000lb license. Personaly for the slight more per year I would opt for the higher, more suitable to the actual truck capability, but some try to save a bit.
David
You could of course drop down to a 20k licensed weight, and not use that last 800lbs, it would be your choice as to how much is saved and how close you are to maxumium GVWR's, and weithor or not that last 800lbs is the difference between a good profit on the haul and not so much.
David
The whole issue about axle rating vs. wheel rating in regard to what's legal is a big damn debate. Some say you can't go over the vehicle rating BUT most DOT officers will go by the rule that front axle can't be over 12k, drives and trailers can't be over 34k. Of course we can support 34k on our axles, but I've read of guys doing fine with that "rule" in place. I'd like a DOT guy on here to please clarify that. Ford say my RAWR is 8250, but Dana says it's 11,000- and then my combined weight carrying capacity of the 4 tires are just over 12,300#. So which does the DOT see as the max you can use?? I've had 9500# on my rear for over 500 miles with no issues, but I did add a cheap set of helper springs. The most I've ever hauled is 32k- got the load through uship- but when I get back from Afghanistan it's gonna cost at least $2k to start legit. The pic below is my 32k gross load.
How do you come up with such BS?
Everywhere else you can drive a straight truck up to 26k without a CDL and combinations up to 36k depending on the trailer size.
