Ipc replacement
Old Feb 10, 2012 | 09:30 AM
jerkypants's Avatar
jerkypants
Ipc replacement
Hi all, I just got word crom the mechanic it is the icp sensor.
He is getting numbers from ford on the parts.
Is there anything else he sould do at the same time, that makes sense?
Old Feb 10, 2012 | 09:32 AM
jerkypants's Avatar
jerkypants
Oh yeah, it is an 2005 F350 FX4 lariat superduty
Old Feb 10, 2012 | 09:49 AM
cartmanea's Avatar
cartmanea
ICP Sensor is a piece of cake on an '05, no need to do anything else at the same time since there isn't much labor involved.
Old Feb 10, 2012 | 10:51 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
I think they recommend the pigtail, from that sensor when you do it. It might be contaminated with oil...
Old Feb 10, 2012 | 06:17 PM
cheezit's Avatar
cheezit
on 03 yes all the time.. later trucks not so much
Old Feb 10, 2012 | 06:28 PM
cartmanea's Avatar
cartmanea
Mine was leaking, but I didn't bother changing the connector. Over $50 for a pigtail is ridiculous! I really don't understand why they have you splice the harness instead of just cleaning the plug out with electronics cleaner like I did.
npccpartsman's Avatar
npccpartsman
LOL--it takes about 30 seconds or less to change the ICP on an 05. Pigtail maybe 5 minutes if the tech is SLOW.
Old Feb 10, 2012 | 06:29 PM
cheezit's Avatar
cheezit
tim I just did one it took me 13 hours. but it was attached to the new long block
Old Feb 10, 2012 | 07:41 PM
69cj's Avatar
69cj
You always seem to have a caveat!
Old Feb 11, 2012 | 09:08 AM
jerkypants's Avatar
jerkypants
Once again people...thank you very much for the help, advice and occasional entertainment.
If I had the proper scan tool I would have done it myself. I am not a mechanic, but am bright enough and analytical...so I usually get by.
Two questions though.
Best scan tool for a non mechanic
What gauges should I have in my truck
Thanks again, w/out your guidance, it would be very tough to do a lot of this on my own, and save a good chunk of change.
Jerky
Old Feb 11, 2012 | 09:09 AM
cheezit's Avatar
cheezit
AE is about as good as it will get for home use.
scangauge does a bunch so far as gauges go
mrwrench
Jun 25, 2018 11:10 PM
blazin_teg
Jul 15, 2013 12:52 PM
JOHN2001
Aug 9, 2012 09:21 PM
Z06PSI
Dec 8, 2010 07:58 AM
belle3006
Oct 23, 2007 11:07 AM
