1978 - 1996 Big Bronco
water pump problems
Old Feb 9, 2012 | 08:55 PM
mater73's Avatar
mater73
water pump problems
well today i was working on my bronco and i was taking the water pump off to replace it. everything was going smooth untill it came time to take the bolts off that hold the water pump on. the up side to this is that 4 out of the 7 came out with very little problems it took some sweet talking and a few squirts of pb blaster but the summited and came out. however the other three wanted to be a pain in the *** and break off. the good news is they broke where i can still get them out. i got them soaking in pb blaster now and im going to spray again tomorrow morning and through out the day and try to get it off tomorrow afternoon after i heat them up. so we will see if tomorrow is any better.
Old Feb 9, 2012 | 09:02 PM
GruesomeJeans's Avatar
GruesomeJeans
Good luck friend Broken bolts can be a PITA if they really want to be.
Old Feb 9, 2012 | 09:07 PM
Edgethis's Avatar
Edgethis
I dread replacing my water pump because I figure that with my luck, every bolt will break off flush with the block. Good luck with your bolts, hope you can get them out without too much hassle.
Old Feb 9, 2012 | 09:09 PM
GruesomeJeans
I think with mine if they did break flush, i would possibly have enough room to drill them a little to get a reverse bit on but i am not sure...
Old Feb 9, 2012 | 09:19 PM
mater73's Avatar
mater73
Yeah I got lucky they didn't break flush with the block. The only this is they are rusted really bad so I just hope they don't break anymore.
Old Feb 9, 2012 | 09:54 PM
GruesomeJeans
Well one product to buy for that kind of thing is Seafoams Deep Creep. It works pretty well, me and EdgeThis like it. If PB works for you thats good too, i am armed to the teeth with WD-40, PB, and DC so bolts better fear my wrath
Old Feb 10, 2012 | 05:01 AM
mater73's Avatar
mater73
Thanks gruesome jeans I will get the DC today and add that to my arsonal.
Old Feb 10, 2012 | 05:12 AM
b4hntn's Avatar
b4hntn
I used a little heat and carefully turned back and forth to remove a couple of my bolts.
Old Feb 10, 2012 | 06:43 AM
Edgethis's Avatar
Edgethis
Deep Creep is Amazing! I recommend it for almost everything. Doesn't leave any residue or smell like PB Blaster and WD40
Old Feb 10, 2012 | 11:17 AM
mater73's Avatar
mater73
so i have so far put pb blaster and sea foam DC on the broken bolts and i have also heated them up but im not sure if im heating them hot enough how hot should they get and did you use just a regular pair of vice grips? the vice grips that i have dont seem to be getting a good enough grip. is there another trick that you or anyone else on here knows?
Old Feb 10, 2012 | 12:37 PM
AbandonedBronco's Avatar
AbandonedBronco
PB Blaster smells like fermenting bananas... I'm not a fan.
Works well though.
Old Feb 10, 2012 | 12:54 PM
b4hntn's Avatar
b4hntn
I would let it cool again. Try to heat around the bolt, not the bolt. Try heating just the timing cover first and not the block until necessary. Heat the block cast iron slowly if necessary. I used regular vice grips as tight as I could get them and rocked them back and forth a little at a time.
Old Feb 10, 2012 | 01:11 PM
mater73's Avatar
mater73
Ok thanks I was heating the bolt that might of been my problem
Old Feb 10, 2012 | 03:54 PM
critterf1's Avatar
critterf1
Get them hot and hit them with a hammer, most of the time this will loosen their grip.
Old Feb 10, 2012 | 09:02 PM
mater73's Avatar
mater73
well i had no luck today. i got map gas and was trying to heat with that but it wasnt getting anywhere near hot enough.. i also went as far as buy a hammer drill to try and get a grip on the broken bolts and that didnt even budge them. i have use alot of DC on them with no progress, and even hit them with a hammer. so tomorrow im going to have it towed to an automotive shop i have access to and maybe ill be able to get them off there and get it put back together and back on the road.
