1978 - 1996 Big Bronco
water pump problems
Old Feb 10, 2012 | 11:35 PM
GruesomeJeans's Avatar
GruesomeJeans
I think if the heat treatment combined with DC and a hammer doesn't get it... You could try clamping the vice grips on as tight as you can and hitting that with a hammer. Maybe the sharp impact will break it loose. Of course there is the possibility of the stud breaking more so be careful.
Old Feb 11, 2012 | 05:00 PM
mater73's Avatar
mater73
well made progress today but in the same note the day started rough with the bolts breaking off more in the timing chain cover. so i busted the left and right bolt guides on the timing chain cover and it freed the bolts and they turned right out. so today i have replaced the timing chain cover and gaskets and got all that put back together. tomorrow i have maybe 4 hours left of work to do with puting the new water pump on, tstat, fan pully and fan, fan cover, reconnecting hoses, and changing the oil and replacing the coolant. and i think thats about it. feels to to know that i made progress today.
Old Feb 11, 2012 | 06:49 PM
GruesomeJeans
Nice it's a good feeling doing this kinda stuff on your own. Unfortunately i really wanted to get my tranny out today but i couldn't get ahold of the guy i am going to to get it rebuilt to make the appointment and to get needed information.
Old Feb 11, 2012 | 07:07 PM
b4hntn's Avatar
b4hntn
Sigh! Smile! Good single malt or your favorite beverage! Tomorrow be sure to get a really good sealant on both sides of the WP gasket.
Old Feb 11, 2012 | 07:09 PM
mater73's Avatar
mater73
Well good luck and thanks for your help ill let you know how everything else turns out tomorrow when its all put back
Old Feb 11, 2012 | 07:11 PM
mater73's Avatar
mater73
Lol yeah tomorrow when it done going to have a few celibetory beers. And also using RTV.
Old Feb 12, 2012 | 07:50 PM
mater73's Avatar
mater73
got it done today now its on to getting the heat to blow hot and hard, and also to figure out why my engine temp gauge isnt working. any ideas on that?
Old Feb 13, 2012 | 07:49 PM
GruesomeJeans
Temp wire unplugged, gauge broken, there could be quite a few things but it shouldn't be too bad.
Old Feb 13, 2012 | 08:16 PM
mater73's Avatar
mater73
Do you think it would be an inexpensive fix?
Old Feb 13, 2012 | 08:28 PM
GruesomeJeans
Ya for the most part. It could be a blocked hose or the thermostat is shot. Thats what i would start with and if it doesn't work still then maybe it is something else. a replacement gauge i think is pretty cheap too.
Old Feb 13, 2012 | 08:44 PM
mater73's Avatar
mater73
Well I replaced the t-stat when I did the water pump and that didn't fix it like I thought so ill check the wires to the guage and she where that gets me
Old Feb 13, 2012 | 09:22 PM
GruesomeJeans
Ok well if you are able to get it to go through your heater core and it does get hot then i would be the gauge.
Old Feb 13, 2012 | 09:28 PM
  #28
Edgethis's Avatar
Edgethis
A good coolant flush is a start. If you're gonna do that then nows a good time to replace hoses too. Did you check to make sure the sender is plugged in?
Old Feb 13, 2012 | 09:52 PM
  #29
GruesomeJeans
Good thing he came to the rescue... My brain isn't working right lately :/
Old Feb 14, 2012 | 04:50 AM
  #30
mater73's Avatar
mater73
I haven't checked anything on it yet going to today. Where is the sender plug located at?
