Speedometer gear:
Old Apr 23, 2003 | 03:31 AM
offroad72762's Avatar
offroad72762
Speedometer gear:
How do you install a speedo gear? (C-6)
Old Apr 23, 2003 | 08:59 AM
73Custom's Avatar
73Custom
Speedometer gear:
Which one, there are two? One is in the tailshaft of the transmission and requires the end of the trans come off. The other gear is attached to the speedo cable and is easy to replace. There is a one bolt retainer that holds the cable into the rear of the trans, remove the bolt and pull the cable out of trans. The gear is attached to the cable with a clip that slides off the gear. Then the gear will slide right off the cable. Assemble in reverse order.
Why do you need to replace the gear? Is the speedo not working or not reading correctly?
Marty
Kerrie
Feb 4, 2008 05:07 PM
BigMattXXL
Jan 6, 2003 09:33 AM
Ford Truck Racer
Sep 30, 2002 10:20 AM
Varnish
Jun 25, 2002 02:52 PM
FTE Ken
Jan 2, 2002 04:16 PM
