help!!
Old Feb 9, 2012 | 03:36 PM
2506deer's Avatar
2506deer
help!!
tried to look this up with no luck . Can I install a 79 steering wheel on a 77 f 150 and will I have any problems
Old Feb 9, 2012 | 03:58 PM
JB78f150's Avatar
JB78f150
I think you can but for some reason I think that the shafts are different lengths but I could be thinking of another vehicle.
Old Feb 9, 2012 | 04:06 PM
earthquake68's Avatar
earthquake68
I think the steering wheel will fit. The column may be different, but I'm pretty sure the wheel fits.
Old Feb 9, 2012 | 06:05 PM
starwriter's Avatar
starwriter
I think 77 was the cutoff for steering wheels and the 78-79 wheel is different. The wheel will physically fit but the pin that hits the cancel cam is different, the outside diameter of the shaft is larger and the horn is 2 spring loaded pins not just 1. I was able to make a 79 wheel work on my 77 by grinding down the shaft but it took an evening in front of the tv with a dremel.
Old Feb 10, 2012 | 08:48 AM
2506deer's Avatar
2506deer
thanks
thanks for the input it sure helped
lalberts
Mar 15, 2017 11:01 PM
79 posi
Dec 30, 2006 02:09 PM
Sgt Wonderful
Mar 5, 2005 02:40 PM
oem78
Nov 1, 2004 06:52 PM
GoldenDually
Dec 7, 2003 10:21 AM
