Grant Steering Wheel
Old Dec 14, 2006 | 11:34 PM
79 posi's Avatar
79 posi
Hi all - looking at putting in a Grant steering wheel in my 78 f-150. It is 4spd, not tilt column. I did some searching on here and it seems like most people have problems with the horn buttons or turn signals. I have ordered the wheel and the accompanying adapter kit, but is it worth trying if i want to make sure both still work appropriately?
The instructions also mention that I may have to cut off a stub on the end of the steering shaft. If this is done can the original wheel be put back on?
I don't want to get into this, decide the wheel is a piece of crap, then not be able to put my wheel back on.
Also, is a puller necessary to get the original wheel off?
Are there more success stories out there that I'm not seeing?
By the way, it is the wood Grant wheel in the LMC catalog (not the one with the billet adapter).
Thanks!
Old Dec 15, 2006 | 02:11 AM
Alvin in AZ's Avatar
Alvin in AZ
Good questions. :)
I'm wondering the same things. :)
Alvin in AZ
Old Dec 15, 2006 | 02:44 AM
Mil1ion's Avatar
Mil1ion
Use a puller. I have seen guys break and smash the broken steering wheel into their face
There are a few Grant steering wheel threads in this forum.
Old Dec 15, 2006 | 09:10 AM
beartracks's Avatar
beartracks
I've got a wood Grant "challenger" wheel on my 77 and I like it. I would use the upgraded horn button assembly. The standard one is crap. The better one is available with the Ford logo and has a much better assembly.
I didn't have to cut anything but did add a washer on the shaft to space the collor off of the column as I recall.
Old Dec 15, 2006 | 09:12 AM
Dave Severson's Avatar
Dave Severson
Me too on the washer and the horn kit, everything works fine!!!!!!
Old Dec 15, 2006 | 04:43 PM
flcracker9's Avatar
flcracker9
I also have the Grant wood steering wheel, and also had to add washers to keep it from rubbing on the column. The Grant horn button on mine works fine, but I also had to put a slight bend in the turn signal lever because it was only 1 inch from the wheel, and I kept hitting it when I turned the wheel.
Old Dec 15, 2006 | 07:19 PM
1979f_100's Avatar
1979f_100
I have the Grant wood wheel as well, but used the billet aluminum installation kit ($50) and it all bolted right up.
Old Dec 15, 2006 | 09:15 PM
Alvin in AZ
Cool guys. :)
I'm like a master-washer-adder so I could prob'ly handle that part of it. ;)
The turn signal lever bending sounded really good to me too... right up until it sounded like the turn signal lever needed bending "away". :/
I want to steering wheel to stick-out closer to me, not farther away.
Got any ideas on that? :)
Alvin in AZ
ps- maybe I shold start a thread kinda like 460's "who's got the largest cracks in their original steering wheel contest"
pps- my horn-button-frame is about half contact cement and popsicle sticks
Old Dec 15, 2006 | 09:44 PM
1979f_100's Avatar
1979f_100
the billet installation kit I mentioned above. I can get a picture of it Monday
Old Dec 16, 2006 | 12:03 PM
79 posi's Avatar
79 posi
thanks for the info
Old Dec 16, 2006 | 01:51 PM
Markcuda's Avatar
Markcuda
Talking
Move the seat up ))))))))))))))))))))))))
Old Dec 16, 2006 | 03:43 PM
Alvin in AZ
Originally Posted by Markcuda
Move the seat up ;) ))))))))))))))))))))))))
No kidding, I did that already. ;) (for years and years even)
Shorter people than me move the seat all the way to the back and they make fun of me... but I think -they- are just plumb silly. Reaching for the steering wheel and looking like they are "hanging from it" while cornering and stuff.
YMMV
So the idea is to move the steering wheel a little more towards me and maybe even move the seat back a notch?
Anyway... wanted to say that with all this new information (a little here a little there) in this thread I feel confident in tackling the "Grant Steering wheel picking out adventure". :) I was putting it off because I just didn't know which way to go or what the results would be. :/
Alvin in AZ
Old Dec 17, 2006 | 12:28 AM
Markcuda's Avatar
Markcuda
Question
How many inch wheel is every one putting on their trucks?
Old Dec 17, 2006 | 05:42 PM
flcracker9's Avatar
flcracker9
I installed a 15" (the stock one was 17") to give me a little more thigh room due to the taller bucket seats I installed.
Old Dec 30, 2006 | 02:09 PM
79 posi's Avatar
79 posi
FYI - I went ahead and installed...put updated pics in my finished restoration gallery. All went smooth for me...had to make sure the turn signal cancel lined up with the groove on the adapter. horn works good. May pull apart one more time to try to get wheel straighter (need to turn a bit left while driving straight)
