E4OD Slipping occasionally
Old Feb 9, 2012 | 09:44 AM
shogigei's Avatar
shogigei
I have just purchased a 1996 F250 with 460 engin with a E4OD transmission. During the testdrive everything worked fine. It has since from time to time decided to start slipping in and out of gear. It will do this for a little while then it will quit and go back to working fine. The check engine light will come on then go off. Right now it is off and the truck is working great. Could this be a sensor issue or signs of a catostrophic failure on the horizon?
Old Feb 9, 2012 | 10:19 AM
Lazy K's Avatar
Lazy K
Fuel Injection Technical Library » How To Run a Self-Test Here is a link on how to get any trouble codes without a code reader or you could buy an Equus 3145 code reader for under $30.00 to make life easier. You should get 3 digit codes.
Sounds like a sensor problem so maybe check for codes as a first step.
Old Feb 9, 2012 | 10:36 AM
shogigei's Avatar
shogigei
Thanks I will do this tomorrow morning.
Old Feb 9, 2012 | 11:04 AM
Encho's Avatar
Encho
The Southernmost Mod
You need to measure the ATF level, as a low level can cause the symptoms you're experiencing. To do so drive the truck normally until it reaches operating temperature, then, measure the level while iddling in "Park". You can also check for any leaks under the tranny (pan gasket, front seal).
Old Feb 9, 2012 | 11:15 AM
shogigei's Avatar
shogigei
ATF level
The fluid level is good and the fluid doesn't appear to be burnt. There are no obvious leaks.
Old Feb 15, 2012 | 03:34 PM
shogigei's Avatar
shogigei
Truck is still doing great. No codes came up. I guess I will just have to wait until it starts to act up again and check it at that exact moment.
umpalumpa1985
17
Oct 17, 2022 01:12 PM
Rentaro
Mar 29, 2018 12:33 PM
aclaybor
Feb 3, 2017 01:32 PM
rangergirl94
19
Feb 24, 2012 11:55 PM
92will
Jul 28, 2011 08:28 PM
