Chime and Screen Flash on Acceleration
Old Feb 8, 2012 | 06:42 PM
NStorm's Avatar
NStorm
Hi all,
15k on my Platinum, love the truck. I've had a handful of chimes and flashes of something on the productivity screen, most recent on an acceleration, pretty good, no WOT, but 2/3 or so, hear the chime and see the orange box on the screen, but it is gone before I can see any text etc.
Oil level good, 10% til next change. possible tire sensor? Any ideas? Never had a TPMS prompt. Have noticed it has only been when the outside temp is around 30 degrees F, or lower.
Thanks,
Nels
Old Feb 8, 2012 | 08:28 PM
meborder's Avatar
meborder
traction controll detecting tire spin?
Old Feb 8, 2012 | 08:36 PM
NStorm's Avatar
NStorm
Good thought ( I hadn't gone this direction), the times I've seen the traction indicator, it hasn't overtaken the productivity screen...that I can recall anyway.
I absolutely baby this truck, hardly even tromp on it. Hope this isn't something I should be seeing...and addressing.
Could it be a coolant check indicator? 15k miles, like the 6.7's? Will we get those? But to flash, and not show up in the system...weird.
Old Feb 8, 2012 | 08:54 PM
meborder's Avatar
meborder
bouced it off the rev-limiter?
i have noticed that the trans does some goofy things when you drasticaly change driving patterns. kinda like their adaptive shift strategy rides the short bus, doesn't seem to know what to do.
if it is repeatable, i'd get someone to ride along, possibly even a service tech.
Old Feb 9, 2012 | 06:13 AM
NStorm's Avatar
NStorm
Good point on the rev limiter. I'll see if I can replicate it, unleash the beast so to speak. Thanks!
Old Feb 9, 2012 | 06:36 AM
meborder's Avatar
meborder
for what it's worth, my 2010 at work will act its goofiest when you make sudden changes in throttle inputs, and driving style.
i used to drive it about as easy as you can, but then every time i had to get into it in a hurry, the trans acted all goofy and couldnt seem to get the right gear.
i'd try your usual "granny start" and then once it finds second or third, stomp it to the floor about as quickly can and watch for your display.
i've actualy started driving my truck at work harder than i normaly would because it behaves better if i need to step into it.
not saying that's what's going on for sure, just that it will do goofy things if you normally drive really easy, and then suddenly stomp it.
Old Feb 9, 2012 | 07:10 AM
msgtord's Avatar
msgtord
I found that my work vehicle also responds better if I don't baby it for a day. So I started taking my 2010 out going at least 3/4 throttle a couple of times. I hate to waste the fuel, but it sure feels like the truck runs better.
Old Feb 10, 2012 | 06:11 AM
NStorm's Avatar
NStorm
Thanks for the feedback guys. Couldn't replicate the event yesterday, but did learn I can break the tires loose at 45...Jesus!
I'll keep on her this weekend and see how things go. Thanks again!
Old Feb 10, 2012 | 06:45 AM
meborder's Avatar
meborder
well, we've busted the Traction Control theory then ! LOL
I'll bet you a dollar that jumping on it a few times like you have makes the problem go away, especially if you do it once and a while.
i'm not impressed with the "adaptive shift strategy" in these new trucks. i don't think it works as well as the "smart shift" that it replaced.
but, look at it this way, if i'm wrong i'll mail you a buck!
Mac Attack
6.7L Power Stroke Diesel
May 23, 2012 01:56 PM
blue oval fan
Jun 21, 2011 10:49 PM
djjoshuad
31
Mar 29, 2011 01:23 PM
o4rhm1
Nov 29, 2010 03:38 PM
MisterDave2
2004 - 2008 F150
May 29, 2009 06:08 PM
