6.2L V8 Discuss the 6.2L V8
100k maintenance and performance suggestions
Old 12-16-2013, 08:42 PM
BlueOvalJunkie11's Avatar
BlueOvalJunkie11
BlueOvalJunkie11 is offline
What does everybody recommend to do on a 100k tune up? i was planning plugs, oil of course and fuel filter, anything else i should worry about? And what are some good bolt on performance upgrades besides a supercharger? not sure if i wanna throw a programmer on my truck just yet.
Old 12-17-2013, 07:16 AM
Dave HM's Avatar
Dave HM
Dave HM is offline
IF the oil change was due, I would change it whenever that mileage came up.
Old 12-18-2013, 01:21 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
The good news here for the 6.2L is no traditional fuel filter to change. The fuel filter is part of the fuel pump assembly and inside the tank.
The spark plugs should be changed at 97,500. Besides that...most changes will be fluids. If not changing them, at least checking fill levels.
Mods...hmmm...not many IMHO. Good luck with it!
biz
Old 12-18-2013, 01:49 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
also...Belt, PCV, I would change the diff fluid and transmission fluid also.
Old 12-18-2013, 04:59 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Well, here's my personal maintenance schedule...
Engine Management System
• 100,000 Miles Oxygen Sensor Replace
Electronic Fuel Injection System
• Annual Throttle Body & Assembly Inspect, Clean & Lubricate as Necessary
• 6 Months Fuel Injectors Add Redline or BG Brand Fuel Injector Cleaner to
Fuel Tank
• 30,000 Miles Fuel Filter Replace
Fuel Lines
• 5 Years Rubber Replace
Cooling System
• Annual Anode/Cathodic Protection Inspect
• 5 Years Radiator Drain & Flush System
• 5 Years Hoses Replace
Power Steering
• 5 Years Hoses Inspect & Replace as Necessary
• 30,000 Miles Fluid Drain & Refill
Belts
• 4 Years V-Drive Replace
• 5 Years Serpentine Replace
Transmission
• 30,000 Miles Automatic Transmission Fluid Drain & Refill
• 30,000 Miles Automatic Transmission Filter Replace as Necessary
• 30,000 Miles Stick with Automatic Type Fluid Drain & Refill
Differential
Brakes & Assemblies
• Annual Drums, Rotors & Linings Surface Sand, Degrease, Inspect & Replace as
Necessary
• Annual Fluid- Silicone Type Bleed System
• 3 Years Fluid- Conventional Type Bleed System
• 30,000 Miles Wheel Bearings Inspect, Clean & Repack
Wheels/Tires
• 6 Months Tires Rotate, Inspect & Adjust Pressure
Old 12-18-2013, 05:45 PM
BlueOvalJunkie11
my truck hit 100k yesterday so it is over due on the plugs lol ill be doing all this next week, ill also put one of them nice rear aluminum factory diff covers on it, anyone got a part number? might make it easier for me lol and what are the best plugs to use in these engines? this is in a super duty btw thought about using motorcraft everything
Old 12-18-2013, 10:07 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Don't forget...these 6.2L engines run with 2 plugs per cylinder. Also...YES...Motorcraft everything makes sense to me.
biz
Old 12-23-2013, 07:18 AM
BlueOvalJunkie11
yeah i know 16 plugs lol now just gotta find someone who sells motorcraft besides the stealership lol
Old 12-23-2013, 08:54 AM
rvpuller's Avatar
rvpuller
rvpuller is online now
One of our commercial sponsors does, RockAuto
Denny
Old 12-23-2013, 09:23 AM
BlueOvalJunkie11
local lol gotta do it this week, i went up to advance auto and ordered some
Qwazert
1999 to 2016 Super Duty
27
10-25-2023 09:46 PM
OHSIX6OH
12-05-2010 03:36 PM
brockinfla
1997-2006 Expedition & Navigator
13
10-30-2006 02:39 PM
Chance_Thomas
06-21-2006 10:46 PM
dandep
1983 - 2012 Ranger & B-Series
04-27-2003 05:47 PM
Quick Reply: 100k maintenance and performance suggestions
