coolant changeout
Old Feb 9, 2012 | 09:46 AM
PEI's Avatar
PEI
Originally Posted by Whitey Ford
I am using Cat ELC concentrate because of availability. It costs $19.50 a gallon. Decided to change out the coolant reservoir also. Found a DORMAN 603-213 for $64.99 locally, with lifetime warranty. Figured that I might as well go all the way with this ELC change-out. The original coolant reservoir plastic was getting brittle, and probably didn't have much life left. Plastic technology has improved since 2002, I was told.
Mike
___________
02 F-350 DRW
Thanks .
Old Feb 9, 2012 | 10:34 AM
Bowie's Avatar
Bowie
Just curious what is the other lower plug on the drivers side of those coolant replace pictures.
Old Feb 9, 2012 | 10:44 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Not sure, but if I was to guess, I'd say it was oil related.
Mike
___________
02 F-350 DRW
Old Feb 9, 2012 | 10:49 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Stewart_H
The reason I created that post was because every time these threads came up, peeps were posting links to other forums for Gooch's procedure.
I appreciate that you created the "Gooch's Procedure" thread. It should be a sticky.
I just wanted people to know that the creator of Superdutypsd.com was part of the "Brotherhood". His site has some great info and write-ups.
Old Feb 11, 2012 | 05:39 PM
Whitey Ford
After two years I noticed a little of the coating was gone on the inside lip of my thermostat housing. I wonder why?
I bought six extra gallons of distilled water to flush out the block really good. On the forth and final flush I only pulled the block plugs out. The water came out with a great deal of pressure. If there was anything left in there it surely was forced out.
Ran a super thin line of high temp black gasket maker on the thermostat housing again and was blessed not to have a leak. The 2 block plugs had red factory sealant on the last three threads of the plug, so I did the same thing very lightly.
Hello ELC!
richlars
18
Jun 26, 2018 05:39 PM
JPs2003
Sep 3, 2017 03:46 PM
rawdeal
Mar 30, 2014 05:44 PM
Harley320
Nov 17, 2007 09:57 AM
bigred00
May 3, 2005 08:41 AM
