I have a 97 F-350 it has add a leafs all the way around and I plan to take it back down to stock height with the over load in the rear is there some place I can find the stock dimensions of front and rear u-bolts or if someone knows them its greatly appreciated!! Thanks
If the U-Bolt has enough thread on it, Just take the add a leaf out, torque down the U bolts and use a dye grinder to shorten up whatever is hanging out. Whenever I get different U-Bolts i make sure to get them with 4" of thread on them for this exact reason.
