Need U bolts.
Old May 12, 2016 | 12:03 PM
GAHIGHRIDER's Avatar
GAHIGHRIDER
Need U bolts.
Want to take the add a leafs/blocks out of my rear springs. Best place to get new rear U bolts? ("85 F150 2WD)
Old May 12, 2016 | 12:11 PM
bcamill's Avatar
bcamill
I like to go to the local shop to have them made. Bring an old one with you and have them shorten by what you need. Do you have a diesel truck repair place near you?
Old May 12, 2016 | 12:47 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
If you lower your truck, your user name becomes null and void
Seriously, I do agree with bcamill. If you are reverting to stock rear suspension/spring specs, then you should be able to source the u-bolts, pretty much anywhere. Is there a reason why you cannot use the existing u-bolts?
Old May 12, 2016 | 12:51 PM
GAHIGHRIDER
Better to have new ones on hand in case these need to be cut off, or they snap .
Old May 12, 2016 | 12:52 PM
bcamill's Avatar
bcamill
I do not recommend re using the existing u-bolts. U-bolts are designed for a one time use. The threads are shaped like a triangle and upon tightening them the thread distorts to keep it from becoming loose. I am sure many have re-used u-bolts before, but it is not the best option.
Old May 12, 2016 | 01:00 PM
WhatsAChevy?
Agreed
I have reused them with lock washers and/or double nuts but I do agree that it is best to use new. Cleveland Spring is local so I have always used them.
They built and installed my '97 Ranger springs at 175k miles (Ford spring breaking issue) along with new hangers. I think they will outlast the truck, and it is now at 300k + miles.
Old May 12, 2016 | 01:05 PM
bcamill's Avatar
bcamill
Its funny that you just wrote that. I was going to add that the factory does not use lock washers as there is not need and if you have them on there, someone reused them.
Old May 12, 2016 | 01:07 PM
WhatsAChevy?
Yepperz....
Old May 12, 2016 | 01:19 PM
WhatsAChevy?
I will be the first to tell folks, always go with OEM/LKQ whenever possible but there are times when a "temporary" solution might be necessary. And I'm very guilty of temporary solutions from time to time
Old May 12, 2016 | 05:58 PM
FuzzFace2's Avatar
FuzzFace2
First place would be a spring or truck shop. Around here the truck shop along with most others are only open M-F and I just cant get to them because of my job.
I did find Auto zone sells U bolts but of the 2 or 3 I checked with did not have the size I needed in stock so will need to order them.......soon as I want to get the rear back under my truck.
BE WARNED! if you cut the U bolts be careful as they have stored energy.....don't ask how I know.
Dave ----
Old May 14, 2016 | 04:40 PM
WhatsAChevy?
"BE WARNED! if you cut the U bolts be careful as they have stored energy.....don't ask how I know.
Dave ----"
Uh Oh....somebody got "biffed"
Old May 14, 2016 | 04:51 PM
FuzzFace2's Avatar
FuzzFace2
Dave ----"
No I was lucky but scared the sh** out of me!
I only cut them because my impac gun would not budge them.
I now have a MAP gas torch. Little heat wrench always get them off.
Dave ----
Old May 14, 2016 | 07:13 PM
Diesel_Brad's Avatar
Diesel_Brad
Bronco graveyard
Old May 22, 2016 | 09:30 PM
redbayredneck's Avatar
redbayredneck
I got the ones for my 86 F250 from Bronco graveyard. None of the local parts stores carried the size I needed.
Had to use a breaker bar and two cheater bars (actually a two piece jack-handle) to remove the old ones because my impact wouldn't budge them.
Old May 23, 2016 | 01:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
EOTZ-5705-K .. U-Bolt / Obsolete
1980/83 F100 / 1980/91 F150 2WD Regular & Super Cab without auxiliary spring.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
DEWEY MOORE FORD in Hughes Springs TX has 4 = 903-639-2516.
