Front Axle
Old Feb 7, 2012 | 01:28 PM
CalCity's Avatar
CalCity
Front Axle
Took my truck to ford for a suspension issue and they found that the right front axle is bad. They want $735 for a new one. Any thoughts on a cheaper aftermarket axle that is just as strong if not stronger?
Old Feb 7, 2012 | 02:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
What did they say was wrong with it?
Look in a salvage yard if it is bad.
Old Feb 7, 2012 | 02:02 PM
Bonanza35's Avatar
Bonanza35
Junk yard. I don't know why it went out but just replace it with used if it where me. Its apart they have to put it together, find one.
Chet
Old Feb 7, 2012 | 02:04 PM
Studawg's Avatar
Studawg
Thread Ender
To the Ford dealer? The "right front axle is bad"? I would tell them to take that new axle and shove it so far up.....well. I had been hearing a knocking/rattling noise coming from the front end, so I had the dealer look at it when they were doing a recall. They said I needed new ball joints, to the tune of $950. I said no thanks. Turns out I mounted my Ranch Hand bumper too high and it was hitting my fender on bumps, which I figured out while driving my truck over a speed bump while a mechanic I know stood outside next to the bump and watched and listened. I dont even think the technician at the dealer drove it.
Start explaining your symptoms, then start searching on this forum, and I will bet you can save yourself quite a bit of money. I have learned that dealership service departments spend about 0.0 seconds diagnosing any problem and just want to throw new parts at everything.
Old Feb 7, 2012 | 10:09 PM
CalCity's Avatar
CalCity
It turns out that it was the outer shaft. There was a worn spot down by the u joint. They said that they cannot order the outer shaft by itself. They have no problem with me bringing in my own parts for them to install. This is something that I would normally change out by myself but if any of you have read any of my previous posts than you would understand why I am fed up with this damn truck. I found one on summit racing for about $190 but if anybody can find a better one than I am on board.
Old Feb 7, 2012 | 10:11 PM
CalCity's Avatar
CalCity
Oh, and anytime a dealer o rshop tell me a part is bad I always want to see it before I let them do anything. I usually don't take my vehicles into a shop because I ant stand people touching my vehicles. But some times I get so frustrated I have to take it in.
Old Feb 7, 2012 | 10:26 PM
snakedoc's Avatar
snakedoc
$735 for one axle i can sell you front and rear for $675 shipped to you.
that is a rip off. run from them.
Old Feb 7, 2012 | 10:33 PM
BigAlsPSD's Avatar
BigAlsPSD
Outer shaft shouldn't be too pricey, I've used Randy's ring and pinion they have the entire stub axle Yukon outer stub axle for '98 and newer Dana 50/ Dana 60 - YA D2002692
Then 4wheel parts lists just the outer here http://www.4wheelparts.com/Drivetrai...n=D%2fS2002692
Old Feb 7, 2012 | 10:37 PM
CalCity's Avatar
CalCity
The truck is there for other reasons so it is torn apart right now. This is just something else that they happened to find. Can somebody please check out this outer shaft that I found and let me know if this will work. Alloy USA 10652 - Alloy USA Front Dana 60 Axle Shafts - Overview - SummitRacing.com
Old Feb 7, 2012 | 10:40 PM
BigAlsPSD's Avatar
BigAlsPSD
That would not be a direct replacement, you would need new hubs too.
Old Feb 7, 2012 | 10:42 PM
timmyboy76's Avatar
timmyboy76
My buddy just bought an 01 the other day, and just got it out of the shop a few hours ago. He text me now say'n bill was $2000.. Had the symptoms your talking about.
Old Feb 7, 2012 | 10:45 PM
CalCity's Avatar
CalCity
Found this one at bronco graveyard.com. Super Duty Dana 60 Outer Axle Shaft
Old Feb 7, 2012 | 10:48 PM
BigAlsPSD's Avatar
BigAlsPSD
There you go, that will work, and I think they are a sponsor too, I forget about them sometimes.
Old Feb 7, 2012 | 11:11 PM
CalCity's Avatar
CalCity
They are also trying to get me for two seals. I think that these are the two. Super Duty Inner Tube Seal and Superduty D50 & D60 Hub Vacuum Seal
These would be replacements for Ford part #s: F81z-3254-CB and BRS-84
ford2012f
2009 - 2014 F150
Mar 20, 2015 08:55 AM
tmm313psu
Aug 8, 2010 05:01 PM
billiejoe86
Sep 27, 2003 06:51 PM
thewhiteford
Aug 12, 2002 09:43 PM
jeebs
Sep 22, 1999 11:58 AM
