front shackle flip kit
Old Feb 7, 2012 | 01:12 AM
jacked 86 f250's Avatar
jacked 86 f250
Looking for a way to do a front shackles flip kit with a 5-6 inch lift to go along with my 12 inch springs. I have a high pinion Dana 60 going in also
Old Feb 7, 2012 | 09:44 AM
blucollar4xford's Avatar
blucollar4xford
Cutting and welding, my friend. I've considered using the front hangers and shackles off of a 78-79 f250, but they're gettin a bit harder to find in junk yards nowadays. That and I'm not really sure it's worth all the trouble (I assume you mean to put the shackle @ the rear of the front springs?)...whats wrong with the stock setup (other than a harsher ride)?
Old Feb 7, 2012 | 06:19 PM
Franklin2's Avatar
Franklin2
There is a company that makes this kit. They say it will fit an older truck with some front frame mods.
92-97 F-250/F-350 front shackle reversal - Sky's Off-road Design
Old Feb 7, 2012 | 06:23 PM
jacked 86 f250
shackle lift
Trying to figure what differance there is in the frame horns between my 86 and the 92-97 frame horn that is where sky said the differancr is. What nods do I need to do
Old Feb 8, 2012 | 12:56 AM
dohc_chump's Avatar
dohc_chump
This space for rent...
The difference is the crumple zone. Our trucks don't have them...
Old Feb 8, 2012 | 08:09 AM
blucollar4xford
I think that's just the f150's...the 250 looks similar, but no "accordion" pattern for the crumple zone
Here's an f250 frame from that era (ignore the ranger body/mods)
...aaaand here's one I thought you'd find interesting (guess its from fullsizebronco.com)...
That's your kit being fitted under an 80-91 frame
Old Feb 8, 2012 | 08:20 AM
jacked 86 f250
That don't look to hard
Old Feb 8, 2012 | 08:28 AM
blucollar4xford
Might want to google it before making any purchases to see exactly what all it entails, but it looks pretty straightforward. It IS a kit, after all. Here is the link that the pic came from, hope it helps!
Sky Manufacturing - FSB Forums
Old Feb 10, 2012 | 03:17 AM
jacked 86 f250
got my springs in
Look to b bigger that 12 inch
Old Feb 10, 2012 | 03:21 AM
jacked 86 f250
lift installed
I don't know how to post pics on here
Old Feb 21, 2012 | 12:43 PM
jacked 86 f250
I'm trying to post a new thread can't figure out. Anyway I need help I swaped a 89 Dana 60 into my 86 f250 with a set of 12 inch springs running same tires an wheels I had before. It looks like my caster is pointed up an my yoke on axle is down alittle don't have drivrshaft in it yet. I can't go over 25 miles an hour because the truck will vilently bounce an shake. We ajusted the toe in on front an don't know what. Is goin on any help would be great!! If easier I can b reached at2172463572 or here on thread
Old Feb 21, 2012 | 01:12 PM
ctubutis's Avatar
ctubutis
Put your pictures up on a hosting site (photobucket, flickr, whatever) and use the IMG code to make 'em show up inline with your text.
Or, you can upload 'em to an Album you create here on FTE, use the same IMG code in your posts, or merely give links.
This should help:
User Gallery & Picture Display Help - Ford Truck Enthusiasts Forums
https://www.ford-trucks.com/forums/1...he-forums.html
To start a new thread, go the 80-86 front page, then click the button.
Old Feb 21, 2012 | 07:22 PM
Franklin2's Avatar
Franklin2
What is a "12 inch spring". Is that 12 inches of lift? Plus 6 inches more from the axle flip? You have 18 inches of lift?
Old Feb 22, 2012 | 03:08 AM
jacked 86 f250
Swaping Dana 60 added about 2-3 inches. I have 12 inch atlas leaf springs front an back sits level
Old Feb 22, 2012 | 12:49 PM
Diesel_Brad's Avatar
Diesel_Brad
The problem is caster. If you dont have enough caster you get death wobble, like you are experiencing
oneofakind97
Offroad & 4x4
Aug 11, 2014 06:59 PM
mort2000
48
May 10, 2013 08:56 AM
t_hess66
17
Sep 18, 2011 09:54 PM
speedsauto
Jan 25, 2008 11:23 AM
KZooDirt
2004 - 2008 F150
Jul 2, 2006 05:11 PM
