General Diesel Discussion
cube van engine to pickup?
Old Feb 5, 2012 | 07:41 PM
h20fella's Avatar
h20fella
i have a 91 ford cube van, body and frame rotten, with a 7.3 diesel. i am wondering if it is an easy job to retro fit this engine into a pickup, and which truck would give me the least amount of hassle? thanks
Old Feb 5, 2012 | 08:55 PM
zhilton's Avatar
zhilton
A F250/F350 from at least '87 through '97...not sure you can go earlier. And there was a frame change when they went to the SuperDuty line for '99 models. It could still work, but you'd need the mounts for the '99-'03 since the frame is wider (a couple of inches at most, but it's wider) on the SuperDuties
Old Feb 6, 2012 | 12:08 AM
rollerstud98's Avatar
rollerstud98
That 7.3 isn't a powerstroke though.
Old Feb 6, 2012 | 05:15 AM
zhilton's Avatar
zhilton
The only difference between the 7.3 IDI and the 7.3 PSD is the heads & fuel system...it's the same block & bottom end. Thus the engine mounts will be the same. Heck, the 7.3 and 6.9 are the same block for that matter.
Old Feb 6, 2012 | 06:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
the only this the 7.3 IDI has in common with the powerstroke is the displacement. no internal parts are interchangable.
and people have put the IDI engines in everything from jeeps to boats.
if you can fabricate, you can put that engine in damn near anything.
Old Feb 14, 2012 | 06:21 PM
Quartlow's Avatar
Quartlow
I went through this on my 93 f-250, the oil cooler is different on the E-series
Old Feb 14, 2012 | 07:24 PM
kb1jid's Avatar
kb1jid
Oil cooler is different from van to PU. Drivers side Exhaust manifold is different And the fuel filter head is on the pass side on van and its on the drivers side in PU
Dr. Johnson
Sep 13, 2013 05:32 PM
bigtexan99
18
Apr 12, 2013 02:02 PM
Prairie Lariat
Oct 27, 2009 10:50 AM
polarisman729
Feb 14, 2008 08:17 PM
sandhillmike
May 25, 2006 11:02 AM
