Temp Problems
Old Feb 5, 2012 | 05:05 PM
devino246's Avatar
devino246
Temp Problems
I took my truck today for the longest drive in 8 months or so. About 35 miles on country roads. It's been bucking and skipping randomly at idle after driving for a few miles, like after it warms up. Of course, it happened on this drive. The temperature gauge, however, didn't move more than 1/8". It was working back in the fall, when short drives would get it up to operating temperature. I was thinking that the thermostat could be stuck open, but I checked the temps around the thermostat housing with an IR thermometer and read a max of 195*. Mixture has been adjusted for highest vacuum, timing checked, no vacuum leaks. Just curious if anyone has any insight.
And on a similar subject, I'm thinking of adding a thermal clutch fan in place of the stock fan spacer. Is it worth it? I assume it will just bolt up in place of the spacer?
Torqflo/Fan Clutch (922710) | 1979 Ford F150 1/2 ton P/U 2WD 8 Cylinders H 5.8L 2BLModified OHV | AutoZone.com
Old Feb 5, 2012 | 05:30 PM
montana_highboy's Avatar
montana_highboy
Not to sound like a broken record, but an aftermarket temp gauge is a must have item, the factory temp gauges are pretty meaningless on these trucks.
Old Feb 5, 2012 | 05:34 PM
devino246's Avatar
devino246
Yeah, that's on the list of things to buy. Just curious if it sounded like the rough idle problem could be tied into a stuck open thermostat. But like I said, the thermostat housing was about 195.
Old Feb 5, 2012 | 06:56 PM
bucks77ford's Avatar
bucks77ford
Have you checked the spark plugs lately? I haven't driven my truck for a while now since it's winter, but before I parked it for the winter, I was having a hard time with the truck running kinda rough and never gave it thought on my plugs because they are basically brand new, but I drive a lot at idle speeds so I figured I'd check and found that they were blackened pretty good. Hopefully, it will solve some of my problem, but something worth looking at considering you have checked many other things.
And I agree with getting an aftermarket temp gauge to see where you are really at before you go trying to troubleshoot more things.
Old Feb 5, 2012 | 06:57 PM
devino246's Avatar
devino246
Pulled 4 of them the other day. Looked good. Insulators were a nice tan color. Did a full tune-up approx 1500 miles ago.
Old Feb 5, 2012 | 07:14 PM
critterf1's Avatar
critterf1
Vacuum leak.
Old Feb 5, 2012 | 07:16 PM
devino246's Avatar
devino246
I've sprayed carb cleaner all around the carb and haven't found a thing. Maybe there is one and I just haven't found it yet.
Old Feb 5, 2012 | 09:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Drive it like ya stole it to clean it out.
And to add... The factory gauge is better at telling outside temps than engine temp.
Josh
Old Feb 6, 2012 | 08:09 AM
devino246's Avatar
devino246
Josh
I did that on a run last week. Gave it more throttle than it's seen in quite a while.
I have noticed a small pool of oily looking crap on the intake, just below the throttle shaft output. It's possible that the shaft is worn and sucking air...or blowing a small amount of gas, which I suppose would yield similar results.
Old Feb 6, 2012 | 08:11 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Since no one else has touched on the fan clutch part of the first post...
To add the clutch you will need both the clutch assembly and a fan meant for use with a fan clutch, as the center hub in the fan is much larger to allow the clutch to fit.
Stock gauges are not real accurate, as mentioned. Something as simple as low voltage or loose/corroded connection can make them read low. Even the wire going to the sender having a few broken strands inside it can lead to false readings.
They will let you know when something is outside the normal range, once you have gotten used to where they usually tend to run, though. Mechanical gauges are far better, if you really want to know what's going on.
Old Feb 6, 2012 | 08:59 AM
devino246's Avatar
devino246
Thanks. Reps sent. Guess I'll save up for an electric fan then.
Old Feb 7, 2012 | 01:54 PM
devino246's Avatar
devino246
Yep, just as I thought. The throttle shaft is worn and has a bit of play in it. Guess I'll have to plan a trip to the junkyard.
Eff1fifty
1997 - 2003 F150
Nov 25, 2014 07:47 AM
fordpride
15
May 12, 2010 09:42 AM
tucan69
Jan 25, 2008 01:23 PM
andym
Aug 23, 2004 01:02 AM
paulmal
May 4, 2002 01:14 PM
