203* T-stat
Old May 8, 2010 | 10:41 PM
fordpride's Avatar
fordpride
203* T-stat
I put my 203* t-stat in today and just curious were ya'll temp gauge is sitting mine is way higher than it use to it's at the R is this normal.
Old May 8, 2010 | 10:42 PM
JamesHajek's Avatar
JamesHajek
Mine sits in the R as well once im all warmed up.
Old May 8, 2010 | 10:50 PM
fordpride's Avatar
fordpride
Good to know because before it wouldn't get pass the N it had me a little paranoid
Old May 9, 2010 | 08:28 AM
Jim Hunt's Avatar
Jim Hunt
I don't have mine yet and I play hell gettin my temp past the o usually barely the n. Is this just because of the thermostat?
Old May 9, 2010 | 01:11 PM
JamesHajek's Avatar
JamesHajek
Yessir, Thats how mine was until i got this stat too. I could barely get it into the NORMAL range. Now it stands a little left of straight up and when im mashing it through the pass, i can get into the M. I asked about if sitting in the R is normal after i swapped mine. Some said yes its supposed to be in the middle of the range, others said no i had air trapped under it. But i went ahead and left it, figure it was normal.
Old May 10, 2010 | 11:39 PM
JamesHajek's Avatar
JamesHajek
Might also want to check your sender too if you still think your readin is off. I replaced both the sender and stat at the same time so i feel pretty confident in my readings.
Old May 11, 2010 | 11:24 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
X2, what he said.
Old May 11, 2010 | 02:49 PM
cowmilker08's Avatar
cowmilker08
Make that a X3, on hard pulls I see M. I was also paranoid.
Old May 11, 2010 | 05:23 PM
fordpride's Avatar
fordpride
This is exactly what mine does plus it hasn't blew up yet so i guess that's good hahaha
Old May 11, 2010 | 06:27 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
Straight up, and in the winter, 10 miles and straight up. The old one in winter after 100 miles still bottom of normal line. Never turned the fan off, now, shew, have to adjust the heat setting to straight up. You will enjoy in the winter, now I plow with the windows down.
Old May 11, 2010 | 06:50 PM
Hussler's Avatar
Hussler
Non Scientific observations in the word "NORMAL" ...
170* = "N" .. verified with laser thermometer at t-Stat head.
195* = "R" .. verified with laser thermometer at t-Stat head.
Verified with engine oil temp as a basis as I don't have a coolant temp gauge.
Old May 11, 2010 | 07:38 PM
fordpride's Avatar
fordpride
I don't use the heat in the winter i live in Louisiana i walk around in shorts in the winter
Old May 11, 2010 | 07:58 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Well I also dont use the heat. But I have a question, is there any other real reason or cientific test that the Diesel engines works better hotter, besides of that, that dieselsite claims?. If so, anyone has been better things with the 203*thermostat? Im really curios.
Old May 11, 2010 | 08:05 PM
fordpride's Avatar
fordpride
when mine get's to full temp it seem's to be more responsive on the go pedal and i think it may have picked up a little mpg. i will know in a day or so on fuel milage when i fill up.
Old May 11, 2010 | 08:35 PM
Hussler's Avatar
Hussler
Yep ...
At idle, in park 170* injector pulse width is 1.2 ms.
At idle, in park 200* injector pulse width is 1.0 ms.
The best thing, needless to say is the really cold mornings. It still takes the same amount of time to heat up the engine but I can tell you there is a Hugh difference between 170* and 200* in cab heat.
