I have the oil cooler off and seperated but like a dummy I did not mark from and back. The tube looks the same on both sides so does it matter? Also I can't tell which orings go where any help is greatly appreciated. My old orings are toasted so bad they all look the same.
If I remember correctly there are locating tabs ont eh cooler itself and it can only go back together one way. That's how the ones were that I've done.
I'd have to look at the rings, but are they different diameters?
It's been a while, I hope someone can give you more input on that.
Yes. Orings are different diameters. And mine were different colors
Yea mine are too but I couldn't figure out which one went where because my,old ones were about the same size. Think I have it figured out now. Going to try to put it together tonight. Do I need to fill the tube with oil?
No need to fill with oil, the cooler is the same end for end has 2 aligning tabs, cant screw it up. Be sure to grease the o-rings before pressing on end caps. I tried pounding them on with rubber mallet, didn't work. Ended up putting entire cooler in a high lift jack and presses together, easy as pie.
i just used gun gr, the o rings should be 2 big green ones and tow small black ones.. its easy to do... make sure you dont over tighten or you WILL pe pulling the motor! tust me! unless your good with jb weild! but that is a hole nother deal! lol i think it tq at 18 foot lbs... seams like that is the number common used on are trucks good luck man!
