HYDROBOOST REBUILD
Old Feb 12, 2012 | 11:31 PM
jem44357's Avatar
jem44357
Nice truck F-250 restorer,
That and I needed to subscribe. I want to have PS and HB on my kit.
Jim
Old Feb 13, 2012 | 03:29 PM
AbandonedBronco's Avatar
AbandonedBronco
I requested the pics and am late on the reply! (Been an out of town weekend).
That's a really nice looking truck. I love it.
I can't wait until (one day) I can do the body work on mine like it deserves.
Old Feb 13, 2012 | 04:41 PM
F-250 restorer's Avatar
F-250 restorer
Thanks, guys. The pix are a 5 years old, and now I can see where the mistakes were made in prep. I did all the work myself, except spraying it. I should have used an etching primer on the cowling, b/c now the paint is pealing off. I should have been more careful about who sprayed it too, b/c he did not get paint in the louvers, or around the windows at the rubber. Oh well.
Another mistake I made, and I'll pass this along so others will know: Don't buy the cheap LMC tailgate. The first time I stacked something on it with it down, the metal flexed and the paint just flaked off where the metal tweeked.
Old Feb 13, 2012 | 07:02 PM
SideWinder4.9l's Avatar
SideWinder4.9l
LMC truck's tailgates are for Chevies an Toyota's....Because they never get worked...
Old Feb 13, 2012 | 07:12 PM
AbandonedBronco
Sorry to hear that. I'll keep that in mind since I'm in dire need of a new tailgate. (The internal mounts for the window track/motor have rusted off, so the bottom of the window's free to move around inside the tailgate).
Old Feb 13, 2012 | 11:36 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Kevin, do you have any problems with your brakes locking up and skidding? Not with your special self applying brakes, just a normal panic stop. My truck likes to skid, drives me nuts.
Sam
Old Feb 14, 2012 | 12:31 AM
F-250 restorer
Sam
Hey Sam. When I did the disc swap I installed an adjustable prop. valve for the rears and it took quite a few stops and starts to get it dialed in, but I managed. Now I only skid when I really stomp on it. One of the rears locks b/c the other is covered with g.oil due to a blown axle sear. If it's not one thing it's the other!
I know I've been really lazy regarding the self-applying issue. I read up on the h.b. system, and found that when seals start to go, then that can be a symptom. So I'm not crazy as certain ex's who shall remain unnamed would gladly state.
Old Feb 14, 2012 | 05:18 PM
Rusty_Old_F250
Hi Kevin, that adjustable prop valve might be the ticket, is yours a willwood brand?
On dry pavement my truck stops ok, but once it rains you can make the tires howl if you try to stop quick! I can only imagine what it's like to be in the little BMW in front with my 4500 lb truck skidding toward his back bumper.
Sam
Old Feb 14, 2012 | 06:02 PM
F-250 restorer
Sam: Is it only the rear wheels that are locking up? Are you sure you have the proper line going to them, and not the line for the front cals? I bought my p.valve from ABS brakes. It cost only $50. Years back when I replaced my oem one it cost over $200.
I would ck my lines first, and try to eliminate any other reason they may be locking before I went and spent money without needing to. Good luck.
Old Feb 14, 2012 | 06:09 PM
Rusty_Old_F250
Thanks Kevin, I'm sure I got the lines right, but I'll keep checking. Don't want to hi-jack your thread.
Sam
Old Feb 14, 2012 | 08:31 PM
F-250 restorer
Sam
Hey, no prob. Glad to try to help. k
F-250 restorer
Feb 5, 2012 03:39 PM
Toreador_Diesel
Apr 10, 2009 12:21 PM
JD717
1947 and Older Ford Trucks
Oct 9, 2005 10:17 AM
bpm32
Jul 28, 2005 09:45 PM
bronco2angel
Feb 13, 2004 07:01 PM
