Super Cooling Radiator
Old Feb 5, 2012 | 12:54 PM
Ken Blythen's Avatar
Ken Blythen
Originally Posted by LARIAT 85
Will the thicker 2-1/4" "super cooling" radiator cool better than the "standard cooling" radiator under normal driving?
As well as having greater surface area for cooling, cores with extra rows of tubes have the advantage of more cooling time.
The water pump is still shifting the same gallons/hour, but if that volume is passing through twice the number of tubes, it's in the core (being cooled) for double the time.
Old Feb 5, 2012 | 02:47 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Considering Ford used a 2 row in the 460 engined trucks it should work fine. I have a Modine in mine, I don't know what will happen when it goes bad, it has a lifetime warranty.
Old Feb 7, 2012 | 10:11 AM
LARIAT 85's Avatar
LARIAT 85
Originally Posted by Archion
The 2 row rad will provide additional cooling capacity. The fan shroud will have to be changed.
Why would the fan shroud have to be changed?
Old Feb 7, 2012 | 10:18 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Different depth. It mounts to the core, which is thicker.
Old Feb 7, 2012 | 10:25 AM
LARIAT 85's Avatar
LARIAT 85
The stock one I have for standard cooling is pretty large, but it appears that it could be spaced out another inch or so past the 1" radiator without hitting anything. It mounts to the top of the radiator on a thin lip that sticks up off the core. Looking at pictures, it looks as if the standard cooling fan shroud I have has the mounting holes spaced further apart than the super cooling fan shroud.
Is there a reason why I couldn't drill holes in the new radiator to fit my current fan shroud?
Old Feb 7, 2012 | 10:31 AM
Archion's Avatar
Archion
It's not the holes that are the issue, the shroud "funnel" itself is deeper on the 1r to keep the opening around the fan the in same spot. The 2r shroud "funnel" is shorter. Some people have also had issues clearing the belt driven accesories clearing the 1r shroud when bolted up to a 2r radiator.
Old Apr 1, 2012 | 08:51 PM
LARIAT 85's Avatar
LARIAT 85
Thank you for the good advice, Archion.
I went with the 2-row Super Cooling Spectra radiator, and it looks great and fits perfectly in my truck. All the necessary hardware was included, making this a nice, easy upgrade. I went ahead and bought a new fan shroud for the Ford dealer to fit the thicker radiator as well. And you are right, it is shorter to accept the thicker radiator.
One question though. The radiator came with a set of four large zinc-colored metal clips. I can't figure out where these go. Do you have any ideas?
Old Apr 1, 2012 | 09:21 PM
85lebaront2
Lariat, you probably got a bonus. They sound like the ones for the bottom of the shroud. Archion can probably say for certain.
Dace
Jun 10, 2016 06:30 PM
Whiplaunch
Aug 19, 2014 11:54 AM
roree
Aerostar
Jun 14, 2008 06:37 PM
Dads79
Mar 7, 2007 01:28 PM
big-boss
Jul 10, 2006 06:09 PM
