Transfer case ID
Old Feb 3, 2012 | 07:12 PM
drileybond's Avatar
drileybond
Transfer case ID
I have a F150 1985 302 A/T and I can't find any info on my Transfer case on the housing there is a number I assume is the casting number it is C13683 and then there is a round tag that says 208F 2 E4TA7A 195AA 5 30 85 261 any thing will help I think my chain is loose but I don't know what chain to get ect.
Old Feb 3, 2012 | 07:46 PM
ctubutis's Avatar
ctubutis
Originally Posted by drileybond
I have a F150 1985 302 A/T and I can't find any info on my Transfer case on the housing there is a number I assume is the casting number it is C13683 and then there is a round tag that says 208F 2 E4TA-7A 195AA 5 30 85 261 any thing will help I think my chain is loose but I don't know what chain to get ect.
E4TA-7A 195AA = NP208 // Used in 1984/86 F150s // all engines/all transmissions
If you want to replace the chain (I'd open it up and verify the problem if it were me):
EOTZ-7A029-A CHAIN (DRIVE) Endless - 84 links - 1 ¼" wide
Parts International Farmersbranch Ford FARMERS BRANCH, TX 75234 Tel. 972-241-8730 http://www.partsinternational.com/index.php has 23 of them
Thank you for providing the tag info!!!!!!!! Makes my job LOTS easier.
Old Feb 3, 2012 | 08:40 PM
bruno2's Avatar
bruno2
New Process 208. We had a smokin good thread going here about a week ago dealing with T cases.
I cant believe that mod didnt turn you onto it.
You should do a bearing and seal kit while your in there. I dont know if those had a pump or not. If so do the pump too. The chain me flopping from excessive bearing play.
Old Feb 3, 2012 | 08:48 PM
bruno2's Avatar
bruno2
Here is a linky:
Chris we should consider cleaning this thread up a bit and possiblly adding some more useful stuff to it and stickying it.
Here is a chain on Ebay:
http://www.ebay.com/itm/NP208-NP241C...item4cfc1cc260
Bearing Seal kit:
http://www.ebay.com/itm/NP208-TRANSF...item588dbc3f4d
Doesnt look as though it uses a pump.
Old Feb 4, 2012 | 11:54 AM
drileybond's Avatar
drileybond
Thanks guys what does the 5 30 85 261 mean?
Old Feb 4, 2012 | 12:14 PM
ctubutis's Avatar
ctubutis
<!-- xx -->
Old Feb 4, 2012 | 03:39 PM
bruno2's Avatar
bruno2
May , 30th 1985
Old Feb 4, 2012 | 05:36 PM
drileybond's Avatar
drileybond
ok thanks for the info
sixpackjack
Mar 5, 2014 06:25 PM
kyle.good
Aug 22, 2010 04:27 AM
1necowboy
Jan 26, 2004 09:20 AM
first time 4x4
May 5, 2003 11:35 PM
