I don't know where you are. It's not filled out in your profile...
If you lose the computer you're going to need another ignition system.
The DuraSpark 2 ignition system (distributor, coil, ignition module, harness) from a truck like mine is probably the simplest reliable thing going.
No points to clean and check.
It was in millions and millions of Ford vehicles from the late '70's until the last of the carbureted trucks in 1987.
Thank you, I live in eastern long island...the ignition sounds easy to find, I would love to go ahead with the project. My motor is real tired, that why I bought that block and heads. I wanted to have a weekend drop in after the rebuild, while still being able to use the truck till then.
North or south fork?
Everything except the harness should be able to find at any parts store.
You can buy a new DSII harness, but some (like Painless) are stupid expensive.
If you can find a late '70's-> early '80's Ford at the junkyard with the blue grommet ignition module; take the coil & bracket, vacuum distributor, ignition module and the wiring harness between them... all the way back to the firewall plugs.
Your EFI truck won't have the proper ballast resistor wire in the cab side ignition wiring, so you might go up under the dash and get that too.
There are dozens of threads on doing this to earlier feedback carb models with the TFI ignition.
Start yourself a new thread if you decide to go this way with your currently EFI truck and some of us can walk you through.
Calverton, right in the crotch of the forks. Well Jim I'll start collecting what I need. Thanks again, sorry for the
Motor is out of the truck and the engine is coming in monday. I asked if the mechanic needed any money for what he's done so far. Stupid question. But I wanted to make sure if he needed any I would get him some for the work he's done so far. He told me he had 28 hrs in the truck??? O.K. The job started as an oil pan and an exhaust manifold job. He started with the exhaust manifold and found that the head was junk. At that time he was up to 300 bucks. Then I decided to scrap the engine and put in a long block. I can't imagine a competant mechanic would take 20 hrs to pull an engine. So as far as right now he is saying the labor costs are up to 2300.00. Is it really possible? I can't imagine it taking that long unless you where using one ajustable wrench and a 6 in 1 screwdriver.
I can't see it either.
I don't have fuel injection but I had my engine out and on the ground in about 4 hours.
IN MY DRIVEWAY, not up on a lift with the benefit of air tools.
Plus, he already had the intake, exhaust and heads off the truck, so the coolant was drained, harnesses removed etc....
I'm going to go see him monday after I calm down a bit. Hopefully some of the labor was doing the ball joints on the drivers side for both of our sake. I kind of got the deer in the headlights when he told me what the labor was up to and didn't ask if he had started on that job.
Go around to a couple of shops and ask for a writen estimate on the same work that the jerk did. Then confront him with the estimates, and bargan him down...he is really slamming you on hours/labor, nice guy
