Sponsored by: Real Truck
a stupid dash question
Old Feb 3, 2012 | 02:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
i swapped the busted up dash panel out in the 02 for a clean one i have had sitting here for close to a year now.
everything went as expected except for one thing. the air bag light is flashing now.
the passenger side air bag switch is not vehicle specific is it??
Old Feb 3, 2012 | 02:50 PM
cartmanea's Avatar
cartmanea
The switch is vehicle specific. Does the new dash have the switch or not have the switch? You can have the crash sensor reprogrammed, but a dealership might fuss if the build is supposed to have the switch for safety reasons.
Old Feb 3, 2012 | 03:04 PM
tjc transport
i ain't rite
the new dash has the switch from whatever it came out of.
i was going to change it, but figured it was a one fits all.
oh well, i guess i am pulling the dash tomorrow to put my switch in it.
Old Feb 3, 2012 | 03:06 PM
cartmanea's Avatar
cartmanea
The switch probably just has the light burnt out, that would set an airbag code. What code does the airbag light flash at key-on? For instance, 32 would be three flashes, pause, two flashes, pause, repeat.
Old Feb 3, 2012 | 03:30 PM
tjc transport
i ain't rite
code 27.
interestingly, the switch light now is not working. before i put the dash in, the switch light lite off for about 3 seconds while the dash was loose.
Old Feb 3, 2012 | 04:37 PM
cartmanea's Avatar
cartmanea
27: Passenger Air Bag Deactivation (PAD) Lamp Inoperative
At least you know what to fix. Ford says the light is not replaceable and wants you to buy the whole assembly, but you can remove it and find the right bulb at Radio Shack pretty easily.
Old Feb 3, 2012 | 05:14 PM
tjc transport
i ain't rite
mehh. i already took the switch out of my old bezel and will put it in tomorrow. i have to take it apart anyway, i screwed up something with the wiring and lost all dash lights and overhead console.
that is what happens when i rush things.
i have a funny felling i shorted out the DRL's and blew the fuse. everything is hooked up through the DRL relay.
Old Feb 3, 2012 | 10:41 PM
xmontex4's Avatar
xmontex4
so that little airbag switch thingy is vehicle specific??? thats good to know my dash needs to be replaced as well
Old Feb 4, 2012 | 12:38 AM
JonathanN's Avatar
JonathanN
Happened to me... PAS burned out so I had an airbag light. Then it burned out to so I got a ding. Got sick of the ding so I fixed the idiot light. Got sick of the light so I fixed the PAS!
Anyways, here's what I did: https://www.ford-trucks.com/forums/9...ml#post9339007
Old Feb 4, 2012 | 07:28 AM
1973Ford2004's Avatar
1973Ford2004
The only way to turn off my switch is with my key, so I would agree it is vehicle specific and changing the "off" light bulb is very easy
Old Feb 4, 2012 | 03:06 PM
tjc transport
i ain't rite
well, the light in the switch was bad. put the switch out of my old busted up dash in and the light came on, and the dash light went out.
now for the lights.
after spending 2 hours re wiring the DRL's and auto lights with new relays, soldered connections and heat shrink tubing, STILL NO DASH LIGHTS!!
as i am getting ready to shoot the truck, the neighbor that knows nothing about cars or trucks comes over and asks what i am doing. so i explained what was up and what i did, and he says did you turn the dimmer?
and there i stood in the driveway, braying like a jackass, as he reached in, turned the dimmer and all the lights came on.
at least i did not make myself look like a total fool by telling him i already bought a new stereo last night to replace the one in the truck with the "burned out" display that lite up when he turned the dimmer.
Old Feb 4, 2012 | 03:16 PM
JonathanN's Avatar
JonathanN
Happens to the best of us... can't tell you how many of those I pulled.
Old Feb 4, 2012 | 05:48 PM
tjc transport
i ain't rite
the funny part about it is this guy does not even know how to open the hood on his car.
SuperDutyScaler
Jan 13, 2012 11:12 AM
wackmaster66
Oct 26, 2011 02:23 PM
Orange '63
Feb 5, 2009 08:40 PM
soundwave
1983 - 2012 Ranger & B-Series
Mar 15, 2006 06:24 PM
robo1990
Mar 24, 2004 10:05 PM
